Results 1 to 5 of 5
Thread: Pool chlorine vs Clorox bleach tablets
    Jul 2010
    South
    Default Pool chlorine vs Clorox bleach tablets
    I buy my pool tablets in bulk. They have 90% available chlorine. The tablets I buy in the grocery store for our toilet tanks are 37%. Can I use the pool tablets in our toilet tanks since the pool tablets are 1/3 of the cost?
    Default Re: Pool chlorine vs Clorox bleach tablets
    I'll let the plumbers answer that but I expect that it will rot the rubber components faster.
    California
    No way. The acidity of the Trichlor along with the high chlorine levels will be corrode the metal and rubber in the tank. The chlorine tablets specifically designed for the tank use chlorine that is pH buffered to avoid such corrosion issues. The Clorox tablets have mostly BCDMH and DCDMH which are similar to bromine tablets for a spa but have both bromine and chlorine. They also include boric acid for some pH buffering.
    Jul 2010
    South
    Thank you very much. I suspected that they would be too caustic. I just wish that the Clorox tablets in my grocery isle were more affordable.
    I found that even the chlorine based ones intended for toilets ("2000 Flushes") rotted the flapper out incredibly fast, so it wasn't worth it. Before you'd know it, the flapper would be leaking and the commode would be running all the time.
  1. Can I use Evolve Bleach Tablets in a Swmming Pool???
    By paigemetoo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2019, 08:27 PM
  2. clorox Triple Bleach
    By vinper in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-09-2013, 04:01 PM
  3. Clorox Out Door Bleach -- Chlorine concentration
    By webfeet in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 11-01-2007, 02:31 AM
  4. Info from Clorox on using their bleach for pools
    By chem geek in forum The China Shop
    Last Post: 09-22-2006, 10:32 PM
  5. How do I convert from chlorine tablets to bleach?
    By reneep in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-12-2006, 03:02 PM
