Marty, you are NOT switching from chlorine to salt. I hate to say this, but if you think that you haven't researched SWG sufficiently. SWGs are chlorine systems: Salt is NaCl--Sodium Chloride and works by breaking salt back into sodium and chlorine, and that chlorine is used to sanitize your water. It's TOTALLY compatible with other forms of chlorine.
I won't go into who makes the best SWG but I can tell you that with an 18,000 gallon pool you don't want one rated for 15,000-20,000 gallons--you want one rated for a larger pool. The unit will work better and last longer because it won't be as stressed. The main reason for SWG is to reduce your need to monitor and add chlorine--it's really great if you have to leave your pool for a few days or a week without maintenance. On the other hand, if you want it to save you chlorine costs, it will take a few years before the cost of the SWG is covered by the chlorine you saved. I like to use liquid chlorine, 12.5% strength, sold in 5 gallon carboys for about $17 each. Since an SWG can run $1000 to $2000 just for the equipment, it takes a lot of carboys saved to pay for it.
