Re: Low pH, Hardness, Alk, where do I start?
Yes, I'm using the HTH 6-way test kit.
You're right about the chlorine and bromine columns. I had not noticed that before, and was thinking it was a chlorine reading of between 3-6ppm, when actually the chlorine is 3ppm.
I got the CYA reading with the HTH 6-way kit. I purchased the kit last year and it contains two CYA tests. I used the second one this year.
16'x48" Intex, 5061 gallons, Intex 1500gph filter, Intex SWCG #54601EG, Filling with water on 6/7/14.
