Results 1 to 10 of 10
Thread: How much Borax to raise pH?
    Default How much Borax to raise pH?
    What is the calculation for Borax and raising pH in pounds of Borax per10,000 gal per pH 0.1 units?
    Northeast Massachusetts - Full Sun - 24' Round AG w/sand filter - Canon-Ball!!!
    California
    Default Re: How much Borax to raise pH?
    Quote Originally Posted by tcjones
    The answer depends on your starting pH and TA level, just as it would with adding any other acid or base. However, at a pH of 7.5 and a TA of 100 the answer is about 8 ounces (weight) so 1/2 pound of Borax (sodium tetraborate decahydrate) to raise 10,000 gallons of water by 0.1 pH.
    That same half-pound of Borax would only raise a pH of 7.0 up by 0.04 while it would raise a pH of 8.0 up by 0.14.
    Similarly, at a pH of 7.5, that same half-pound of Borax would raise the pH by 0.12 when the TA was 80 while it would raise the pH by 0.08 if the TA were 120.
    Do you have a specific current pH and TA level from which you are starting and that prompted your question? Knowing the CYA level is also helpful (though it's impact is smaller).
    Richard
    Sanford, FL
    Well I used 4 lbs of Borax on a 14,000 gallon pool with the TA at 120 - I will test again tonight - but preliminary tests raised it from below 6.8 to ~7.0.
    Completed 8/21/06
    14,000 gallon 3'-6' concrete pool with Diamond Brite
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Hayward Super II Pump - Cartridge filter
    See pictures here http://www.philsimmons.com/family/ga...mages&keyword=
    California
    Quote Originally Posted by Simmons99
    My calculations show that this would raise the pH from 6.8 to 6.95 which is in the ballpark of what you found.
    If you wanted to continue to raise it to 7.4, you would need to add 133 ounces (8 pounds, 5 ounces) more. Also, doing this increases your alkalinity so your TA would then be 147.7 and you'd probably want to lower that, THEREFORE I suggest that you follow Ben's Lowering Your Alkalinity procedure first while you still are at lower pH so you can get your TA down a bit more AND so you can raise your pH while keeping your TA constant (by doing aeration instead of adding Borax). In other words, I don't think you should be adding any Borax at all and instead should just do the aeration at low pH (continuing to add acid until you get to your target TA) and then continue to aerate (stopping the addition of acid) to make the pH rise without affecting your TA.
    Richard
    Sanford, FL
    Okay - I will when I get home - well - I'll just let the kids play that will aerate enough. Can tap water have high TA?
    Completed 8/21/06
    Spa with spillway
    SWCG - Aqua Rite
    California
    Yes it can. If your water is "hard", then it has high TA. Water hardness refers to the combination of both calcium and magnesium (and other minerals, but they are minor), but generally calcium is much larger in quantity than magnesium though this is dependent on the specific water source.
    You can just test your tap water or you can look up the water hardness from your water utility district and then divide this number by 1.4 for a rough estimate of calcium hardness. The following table shows typical nomenclature for water hardness:
    Soft 0-17.1 ppm 0-1 grains/gal
    Slightly Hard 17.1-60 ppm 1-3.5 grains/gal
    Moderately Hard 60-120 ppm 3.5-7.0 grains/gal
    Hard 120-180 ppm 7.0-10.5 grains/gal
    Very Hard 180+ ppm 10.5+ grains/gal
    Some well waters can be well over 300 ppm in hardness. If the water source has passed through calcite rock (limestone), then it can pick up substantial calcium hardness since limestone is mostly calcium carbonate.
    Richard
    mas985's Avatar
    mas985 is offline Lifetime Member Whizbang Spinner mas985 3 stars mas985 3 stars mas985 3 stars
    Pleasanton, CA
    Check out my tap water:
    City numbers
    TA 225-276
    CH 280-354
    PH 7.9-8.0
    Add a SWG and plaster pool, it is no wonder I use 1/2 gallon of acid a week.
    Mark
    California
    Wow, your water is very, very hard. You can try aerating your water (in a bucket or large tub) before adding it to your pool for refill since that will lower the TA. If you do that, you can add acid to it first which will lower the pH to make it easier to lower the TA (i.e. lower the pH and aerate according to Ben's alkalinity lowering procedure). Of course, if you just put in fill water through an automatic floater (similar to a toilet tank), then there's not much you can do except constantly fight the pH rise by adding acid.
    The more troublesome quantity is the calcium since that will just keep getting added to your pool more and more. Eventually, you'll have to drain and refill substantial amounts of your pool water to get that down. Sorry you have such a difficult situation.
    Richard
    mas985's Avatar
    Pleasanton, CA
    TA really has not been the issue since I need to lower PH so much. It pretty much stays 100-120 ppm. CH on the otherhand is a battle. Next winter I will do a refill when the city uses more surface water than well water and see if I cannot start out the season at 200 ppm. It does make me wish I had chosen a fiberglass pool though.
    Mark
    Sanford, FL
    Well it worked - this morning PH is 7.5 and TA is 90.
    Completed 8/21/06
    Spa with spillway
    SWCG - Aqua Rite
  1. Adding Borax to raise PH Level
    By williamsjp in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2012, 05:51 PM
  2. Amount of borax to use to raise pH
    By tcward in forum Pool Chemistry for Intex-type Pools
    Last Post: 05-14-2012, 11:23 AM
  3. How much Borax do I need to raise my pH?
    By DeYoung9 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-04-2007, 07:34 AM
  4. How much borax to raise PH?
    By denanbob in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-17-2007, 01:25 PM
  5. How much Borax to raise pH 0.2 -0.4?
    By Mr Bill in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-26-2006, 08:50 PM
