Results 1 to 5 of 5
Thread: storing muriatic acid
    Michaela521 is offline ** No working email address ** Michaela521 0
    Default storing muriatic acid
    If you live in a very cold place like minnesota should you store muriatic acid in a heated place. It gets very cold where I am too.
    California
    Default Re: storing muriatic acid
    The freezing point of Muriatic Acid (31.45% Hydrochloric Acid) is -46C (-50.8F) (for Hasa; other brands quote even lower freezing points) so unless you live in the Artic, I think you are safe to leave your Muriatic Acid outside.
    Richard
    Ft Lauderdale, Fl
    Richard,
    How much difference does it lower the freezing point if you had a 4 parts water to 1 part muriatic solution in an outdoor tank? I would assume lower than water, but not quite into the negative temps...
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
    California
    Sean,
    The freezing point depression of water is -1.86C/m (3.35F/m) where "m" is molality or moles solute per kilogram of solvent (water) for a non-electrolyte (for an electrolyte such as HCl that dissociates into two parts, the depression is double this amount). So the amount of freezing point depression is solely a matter of the quantity (number of molecules; not weight) of substance dissolved in the water. So, if you dilute the Muriatic Acid (31.45% HCl) with 4 parts water, you dilute by 1/5th. The amount of freezing point depression will get reduced, but by more than 1/5th due the definition of molality.
    31.45% HCl means 31.45 grams of HCl in 100 grams of solution so that means 100-31.45 = 68.55 grams of water. HCl is 36.46 g/mole so the molality "m" is (31.45 g HCl / 36.46 g/mole HCl) / (68.55 grams water / 1000 grams/kilogram) = 12.58 m. So, 12.58 m * (-1.86C/m) * 2 = -46.8C which is about -46 as claimed by Hasa. Diluting the Muriatic Acid by 1/5th is done by volume, so Hasa says that the density of Muriatic Acid is 1.16 g/ml. The example of 100 grams of solution would be 116 ml in volume. You said you would dilute that by 4 parts of water so you would be adding 4*116 = 464 grams of water since pure water is about 1.00 g/ml. So now you would have the same 31.45 grams of HCl in 464+68.55=532.55 grams of water so that gives 1.62 m. So, 1.62 m * (-1.86C/m) * 2 = -6.0C (21.2F). So you are right that the new freezing point will be above 0F.
    [EDIT] This calculation was done backwards. 100 grams of Muriatic Acid solution would be 100/1.16 = 86.2 ml in volume. Diluting with 4 parts water would be 4*86.2 = 344.8 ml which is about 344.8 grams of water since pure water is about 1.00 g/ml. So now you have the same 31.45 grams of HCL in 344.8+68.55=413.4 grams of water so that gives 31.45/36.46/(413.4/1000) = 2.09 m. So 2.09 * (-1.86C/m) * 2 = -7.8C (18.0F). [END-EDIT]
    Richard
    Last edited by chem geek; 12-22-2007 at 04:54 PM. Reason: Corrected calculation (yes, it's tricky).
    Ft Lauderdale, Fl
    Geek, You ROCK. thanks
    Sean Assam
  1. Can anyone tell me where to buy muriatic acid?
    By blessedbeingmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-06-2011, 01:35 PM
  2. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 12:54 AM
  3. How Much Muriatic Acid?
    By TfromNC in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 06:32 PM
  4. How to add muriatic acid
    By BullDean in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-12-2006, 10:51 PM
  5. how much muriatic acid
    By wolfcue in forum Dealing with Alkalinity and Calcium
    Last Post: 06-07-2006, 05:55 PM
