Thread: Pebble Tec Stain
    Default Pebble Tec Stain
    I have some floor returns... called the enviro tech system... just basically returns water via the floor in additional the side way returns... one of them has a yellow stain on the pebble tec around this return...
    What should I do to figure out what is causing the stain? More than likely I think it's from my heater, as the by pass was closed, and when I opened it up, and turned the heater on... a lot of rust went into the pool....
    What can I do to get rid of the stain?
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    Default Re: Pebble Tec Stain
    If you think it's rust, try a Mr. Clean Magic Eraser. If you think it may be metals, then try crushing up a few vitamin C tablets, put them in a sock, or some ph down in a sock, and rub them on the stain. This will take off any metal stains. I have found that rust doesn't respond as well to the vitamin C or ph down - but the eraser works wonders! Hope this helps, let us know
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
  1. pebble tec plaster or not?
    By terpool in forum In-Ground Pool Construction and Repair
    Last Post: 04-25-2012, 11:50 PM
  2. pebble tec
    By bethsg in forum In-Ground Pool Construction and Repair
    Last Post: 07-09-2009, 09:27 AM
  3. Pebble Tec
    By joedinaz in forum In-Ground Pool Construction and Repair
    Last Post: 07-30-2006, 11:38 AM
  4. New Pebble - first tests
    By dawndenise in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-25-2006, 08:08 PM
  5. Pebble Sealer?
    By stever13 in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2006, 12:37 AM
