Results 1 to 5 of 5
Thread: Clorox and Freezing
    Toms River New Jersey
    Question Clorox and Freezing
    Will Clorox freeze if left outside. I have a case of 4 gallon containers at 12% solution. I wanted to store them in an outside shed.
    California
    Default Re: Clorox and Freezing
    The freezing point depression of a 12% Sodium Hypochlorite solution (which also has 9.4% salt due to the manufacturing process of chlorine) is 15.3C or 27F so the freezing point is -15.3C or 5F. So unless you are expecting sustained temperatures well below freezing (i.e. closer to 5 degrees Fahrenheit or below), then it should be safe.
    The full calculation was determined from the following. 12% solution is (approximately; ignoring Trade % vs. weight % distinctions) 12 grams of sodium hypochlorite in 100 grams total. There is also 12*58.443/74.4422 = 9.42 grams of salt (from the way chlorine is produced) so that's 100-12-9.42 = 78.58 grams water. There is 12/74.4422 = 0.1612 moles times 4 for dissociation and salt (there is sodium, hypochlorite, sodium, chloride) so 0.6448 moles solute in 78.58 grams water so in 1000 grams (1 kilogram) that is 8.2 so that times 1.86 is 15.3C = 27F.
    Richard
    Quote Originally Posted by CyberGypsE View Post
    You can always store them at my house...I assure you they won't freeze!
    Rich! Thank You for the info. Will store in shed, temps in Jersey usually don't drop that low.
    Janet, Just what I need a cold beer and a warm heart. Thanks for the offer
  1. Freezing Reagents?
    By hawkeye91 in forum DPD-FAS based testing
    Last Post: 04-01-2011, 06:12 PM
  2. Help...freezing pool equipment!!!
    By poolboy69 in forum Pool Equipment & Operations
    Last Post: 02-05-2011, 05:16 PM
  3. Dolphin Diagnostic and freezing weather
    By SandyDittmer in forum Pool Cleaning: Manual or Automatic
    Last Post: 09-25-2009, 06:48 PM
  4. Help! we may loose power from freezing rain
    By beary in forum In-Ground Pool Construction and Repair
    Last Post: 01-14-2007, 01:18 PM
  5. Protect from freezing?
    By eljefe281 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-03-2007, 02:32 PM
