See if you can find some liner lock -- it's a soft plastic/ vinyl barbed 'wedge' that helps fill the gap in the track that receives the liner bead and keeps downward pressure on the bead so it won't slip out (as easily). Similarly, you could just use a few pennies to keep the bead from slipping out.
How hard is it to get those corners back in on a warm sunny day? The harder it is to get them back in, the more likely they are to pop back out and therefore more area must be secured with the liner lock or loose change![]()
