Don, how are things in Mahwah, other than a leaky filter? Sorry you're having filter issues again, I had hoped the cleaning of the grids would have kept you good for the summer!
I'd open the filter and check the o-ring! Sometimes just cleaning the sealing areas on the filter and rinsing and lubing the o-ring will do the job Otherwise (unless you see a problem with the sealing areas on the tank itself) a SP 2400 K (tank o-ring) replacement should fix it ( ~ $ 25)
If you open it and have any questions, I check this site (first!) almost every night
