Results 1 to 3 of 3
Thread: Pool Calculator
    Alabama
    Default Pool Calculator
    I've looked and can't find it. Is the old pool calculator around here anywhere? Not the online version, but the downloadable one from years ago? I just liked having it on my desktop...and I actually like it better.
    thanks!
    May 2010
    12806 Gaffney Rd
    Default Re: Pool Calculator
    I think you must mean BleachCalc, which you can download from http://richardfalk.home.comcast.net/...achCalc262.exe.
    -- Trouble Free Pool website administrator --
    ------ note added by PoolForum staff -------
    California
    Just keep in mind that BleachCalc has serious errors with regard to borates due to using the wrong units of measure. If you want to use The Pool Calculator on your desktop, you can save the web page or HTML to your desktop so you don't have to be online.
    You should also let Jason know what you like about BleachCalc better since he's always trying to improve The Pool Calculator. There is also an iPhone App of The Pool Calculator.
    (FYI to Jason: links in vBulletin are done using URL in caps and most importantly where the link is in quotes which is not required in phpBB; however, it seems that all links don't work right now for some reason, even if formatted correctly)
  1. Pool Calculator; useful?
    By JimK in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-09-2013, 09:22 PM
  2. The Pool Calculator
    By Scetnk in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-25-2011, 01:17 PM
  3. The BBB System and Pool Calculator
    By thorn138 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-21-2011, 11:13 PM
  4. Kiddie Pool Calculator has an error.
    By grammy in forum General Interest
    Last Post: 07-08-2011, 10:54 PM
  5. pool calculator question?
    By anikahmae in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-16-2011, 06:24 PM
