Bought a used above ground pool and there is no bottom track??????
I bought a used above ground pool and during disassembly realized it does not have a bottom track. They had dirt around all sides of it and the upright support posts have a small track on them. They told me it was a penguin brand pool, but I have not found anything about them online. Should this pool have a bottom track? Has anyone heard of penguin pools before? It has a deck that is made for the pool and is incorporated into the construction of the pool.
Re: Bought a used above ground pool and there is no bottom track??????
Hi ragriffin, and welcome to the forum!!
I looked around the forum and didn't find much on Penguin pools, but I did find some contact information for them. You might try to contact them at the following:
1610 SE 47th Street
Cape Coral, FL 33904
Phone: (239) 542-3410
Fax: (239) 542-5598
General Information Request
[email protected]
Maybe they can answer your questions, and if you do indeed need the bottom track, should be able to direct you to where to get it.
