repairs help fantasea pool
This year I have noticed that some section of the pool side boards that look like ply boards have bowed out word and 2 supporting 4x4 in front of the bow look like the have come away at the very bottom of the pool where the metal track is at plus I see stress cracks on the 4x4 in front of the bowing boards will I be able to repair only theses sections and will it be difficult. Is there a special type of board and 4x4 to use when doing this type of repair.
Thank you in advance for your help
Re: repiars help fantasea pool
I've never repaired an AG pool myself, so I can't help. I'm not sure if anyone here, can. But, I can tell you that if you can EITHER send pictures to [email protected] OR post them yourself with Photobucket, Webshots, Flickr or Picasa . . . you are MUCH more likely to get a helpful response.
Re: repairs help fantasea pool
http://s1170.photobucket.com/albums/...view=slideshow
here are some pictures of the 2x4 post separating from the bottom of the pool will i be able to repair this simply by re inserting the post at the bottom i am also not sure how they are attached to the railing that seems to run along the bottom of the pool
thank you
I think I'm the only other one around here with a FantaSea pool, so I probably have a far more intimate knowledge of their construction.
1: I don't see the U-channel that the bottom of the 4x4 sits in (the wooden truss of the 4x4 and the diagonal are all one manufactured piece. The U-channel forms a rectangle around the perimeter of the base of the pool and is a critical structural element. It shouldn't be buried and needs periodic maintenance (wire-brushing and repainting with Rust-oleum or equiv).
2: The plywood Water Wall is 3/4" marine-grade ply with a plastic vinyl finish on both sides--or is supposed to be.
3: The plywood is attached to the vertical 4x4 from the inside of the pool, under the liner. A special non-bleeding tape is used to cover the screw heads and protect the liner.
4: The 4x4 sits in the U-channel to keep the water pressure from driving the plywood and the 4x4 out.
5: Repairs to the plywood (like replacement) can only be done with the water drained and the liner removed--i.e. at liner replacement time.
6: It looks more to me like the 4x4 has been pushed or jumped out of the channel and the plywood is bowing from the pressure past it. It MAY be possible to push the wall in but it may take some serious leverage (like a hydraulic jack) to move it enough to reinforce it.
7: FantaSea provides, for the non-wood Water Walls, a reinforcement of a vertical treated 2x4 that goes BETWEEN each pair of trusses on two foot centers, but the 2x4 must be in the U-Channel and be long enough to lock in behind the steel truss the supports the deck. Those 2x4s are probably your only shot at repairing your pool WITHOUT draining the water, pulling the liner and removing/replacing the Water Walls.
8: You should talk to FantaSea's tech support. Leisure Living, aka PoolSupplies.com still supports FantaSea pools (but I don't know if they still manufacture and sell them).
9: I'll try to dig up a picture of what my FantaSea looks like--in the structural support dept. You can see the U-channel at the bottom, and the 2x4 supports between the trusses.
http://home.earthlink.net/~dashmanc/pool/wholepool.jpg
You can sort of see construction details in this shot:
http://home.earthlink.net/~dashmanc/...anifoldWeb.JPG
Hope this helps, and hope this is clear.
thank you Carl you gave me more information then i had before we are open to draining the pool for the needed repairs i guess my concern was if i was going to be able to repairs only those sections that have started to pull away or would i have to change everything right now my grandchildren still have a good 10 years before i can let the pool go for good...
You are welcome.
Unlike most AG pools, the FantaSea does not require the water to act as a structural element--it only keeps the liner in place. Everything else is a totally self-supporting structure--I don't think I have any immediate pics of my pool during construction but I can find them if you need them.
