Fiberglass Step with Rust Stains
I have a set of fiberglass steps that has metal wire embedded into it bur covered in fiberglass. We are now getting in the 2nd and 3rd year some small rust spots that don't want to come off ; least with a normal rag or with your fingernail .
My supplier says it is due to something put into the pool, but we've not added anything other than salt water magic mix on a monthly basis.
Thoughts on what caused it and how to clean it?
Re: Fiberglass Step with Rust Stains
No idea, because we don't know what's in your "salt water magic mix". If you have metal in the pool, and rust spots, then it's not hard to figure out where the rust came from. To remove it, log out, go to the "metals" subforum, and read through the sticky on removing metal stains.
Try a magic eraser by mr clean, if that doesn't work, you ca use a very fine sandpaper. Let us know how you do, thanks
Thanks for the replies!
One would think if I am registered I'd see all the forums and not have to log out, but I did and seen more sub-forums, but n ot sure I found the one you were talking about Janet. To Marie, we did try the magic eraser and that didn't work at all. You can feel with your fingernail that it is not just a stain, but have texture to it.
Do you think it is a bubble in fiberglass, or something stuck to it?
No bubbles, it looks as if it is apart of it.
Would it be possible to post a picture?
You can either use Picasa, Flicker, Photobucket, etc., or email it to [email protected] and reference the URL of this thread.
