Neglected Vinyl AGP with Dead Dried Algae
I purchased the pool in February*. It was emptied, folded up, and delivered on the same day. It smelled awful but it was still raining so we left it outside. I haven’t finished the ground preparation yet and decided to get started on cleaning the pool. We unfolded it and sprayed it with a high pressure nozzle and got rid of the sand and debris. I washed the support flaps pool with vinegar and water and a little bleach for stubborn stains. I just flipped it over and it was almost completely dry and covered with dead algae. The colors of algae found are, green/brownish, pink, and black. I started cleaning it with a solution of borax and bleach and used a stiff nylon brush to scrub off the algae. It takes a lot of scrubbing to remove the algae and it will take me several days to remove it at this rate. Would it be easier to set it up temporarily and put water in up to the watermark (1’) to get rid of the algae? The temporary location isn’t level but I have a Gorilla pad that I can set it on. Could I treat the water with chemicals that remove algae instead of scrubbing it off by hand? I had a smaller ABG and only got algae once. It wasn’t dry like this bigger pool but I was able to clean it using liquid pool chlorine and Algae prevention chemical. Please advise. Thank you.
*I paid $250 plus $25 for delivery. It came with all the hoses, and Pentair Clean and Clear filter, a Pentair Whisperflo ¾ hp energy saver pump a Pentair Chlorinator 320, pump timer and a pool brush/sweeper, and heavy retractable pool ladder. The equipment alone is worth a lot more than $250.
Re: Neglected Vinyl AGP with Dead Dried Algae
1. What sort of pool do you have? A Whisperflo is usually an in-ground pump, but it sounds like you have some sort of above-ground pool.
2. If it's an AG pool, it would probably be easier to clean after it was erected and partially filled. It would also be better for the pool -- leaving a pool liner laying folded in the sun isn't a good idea.
Please only use this thread. Watermom has noted that the other one you started is identical and we like people not to do that.
Please forward the pictures you have to [email protected]
Duplicate thread. I had just ordered a subscription and received the confirmation e-mail when I submitted the first one. I went to check to see if it posted and couldn't find it. I did a search and I went through the different forum subjects. I even logged out and logged back in and never found it. Sorry.
Not a big deal. Don't worry about it. We're just glad to have you join us! ;)
