Newbie in need of useful information!
Hello,
I hope I can find some answers to the questions I have. We just set up a 16x48 Ultra Frame Intex Pool. I realized after purchase this pool did not contain cleaning items such as a net/vacuum etc. My question is where should I go to purchase these items? And what exactly will I need? Also, we are in the process of filling pool and I'm wondering if we need to add chemicals right after filling? We chose to use our hose, in place of a water delivery because we figured out it'd be cheaper. What exact chemicals do I need to add (what should I get?) This is all new to us, tried doing my own research but everyone has different likings or ways to do this. We have the Krystal Clear Filer Pump this year (plan to upgrade to salt water next year.) The pool holds 5,061 gallons.
Re: Newbie in need of useful information!
I'll let someone else (maybe Dave who is more familiar with Intex equipment) help you with that part of your question.
But, as far as starting your pool up, the easiest way is to use our Super Simple Startup Recipe: http://pool9.net/ssr/
After you read that, come back if you have further questions.
Welcome to the Pool Forum!
(Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
Thanks, but link says I don't have permission to access it?
Did it come with a surface skimmer? If not, I'd recommend you look at the Intex surface skimmer - It can be a little finicky but will keep alot of debris out of the pool.
I bought a pretty nice extension pole skimmer at WallyWorld that is formed with a thin front edge - it can pick up alot of things on the bottom as well as remove surface debris.
I found the Intex venturi-vac (powered by the hose) inconvienient - I'd add too much water every time I used it. My neighbor was happy with his Pool Blaster battery powered vac. I haven't used one but I've read positive opinions from others.
A brush would also be useful to break up anything that might be clinging to the walls.
. . . membership upgraded.
Here's the stuff Dave mentioned:
The problem is, most folks with Intex type pools do not have an effective vacuum system, and Intex doesn't really have any accessories that are adequate. There are basically two options.
Manual Pool Vacuum:Hydro Tools 1-1/4-Inch Diameter With Swivel Cuff Pool Vacuum Hose, 18'
Poolmaster 27514 Classic Full View Triangular Vinyl Liner Vacuum
Hydro Tools 8351 6- to 12-Foot Adjustable Blue Anodized Step-Up Telescopic Pool Pole
With the manual option, you can certainly remove the debris by vacuuming 'to waste', using siphon. You'll want to over-fill your pool first, before starting the siphon. Tie some sort of weight to the hose, to keep the 'out-of-the-pool' end from flopping back into the pool and breaking the siphon.
You may, or may not, be able to couple the hose to the suction inlet on your pool. If you can work out a way to do so, then you will not lose the water you vacuum with. You will of course get your filter dirty fast.
Battery Operated Vacuum:Water Tech Pool Blaster Max
Water Tech CATFISHPPV Pool Blaster, Catfish
Pool Blaster PBW022MF Micro Filter Bag
If you are interested in the battery vac -- and we've had pretty good reports on this brand -- call Water Tech *FIRST* and make sure that the fine bag will pick up debris like yours. It's possible that it may just go through the bag, so ask first.
Water Tech (PowerBlaster Max page)
10 Alvin Ct. Suite 111
East Brunswick, NJ 08816 USA
Tel: (800) 298-8800
e-mail: [email protected]
Intex surface skimmer @ Amazon
Intex skimmer manual
