Re: Am I on the right track?
Sam_I_am
This is the end of day two with the Bleach at 15 ppm (or above) and my water is much less green now... I'd almost go as far as to say it is bluish... however it is very cloudy blue - but that is progress I believe.
If you're going from green to cloudy blue, that is great progress...keep the chlorine at 15 and keep your filter running....the cloudiness is dead algae that the filter will have to eliminate.
I would not put any more copper-based algaecide in the pool...once the copper gets to a certain level, if you don't keep the pH and alk low, it will start staining your pool, and from there pool care gets quit a bit more difficult. CarlD is right--at that point, Marie is the one who will need to help you since she's our resident expert at staining.
We used to speed up the clearing proccess by using a flocculant. When you are sure you have the algae dead, you might want to try it.
We never had the patience to wait for the filter to clear it up and that helped it along. :)
Thank you everyone again for your assistance.
I just vacuumed the pool and backwashed. It actually looks more cloudy now... and am thinking that the filter is struggling a bit with clearing up the dead algae.
I may take your suggestion Doggie (thank you) and add a floc - I have used them periodically in the past with mixed results... but it may in fact help the process (perhaps I'll buy a skimmer basket sock as well?). Does anyone recommend a specific Floc. I have seen the granular type you pour into your skimmer, the puck type that sit in your skimmer, and also the blue liquid (polysheen or something).
Any recommendations?
As for a good test kit... this has been somewhat difficult for me, because I live in Canada, most online companies will not ship to Canada. So getting a quality test kit in a timely fashion has proven to be difficult.
I am currently looking at purchasing one through Waterwarehouse (but I'll have to have it delivered to my mailbox south of the border) then bring it accross the line. I'm considering duraleigh's Troublefreepool.com site as it looks like they have a good kit for sale.
Any comments about kits and where I could purchase one (I'm particularly interested in one that shows free and complete chlorine and up to 50 ppm.
Any assistance would be greatly appreciated.
Dave
The floc we use is this: http://outdoor-living.hardwarestore....nt-656270.aspx
Being in Canada, I have no idea if you can get it there. But it's most def a liquid treatment. It's worked very well for us when we used it in the past.
Sorry to hear it's such a pain to get stuff delivered to you there! I hope you find the things you are looking for. :)
edit: I'm sure you know this already, but be sure to vac to waste if you use the floc treatment
Here's who Taylor says to contact for Canada:
For all Canadian orders, contact Lowry & Associates in Newmarket, Ontario:
905-836-0505 (voice)
905-895-4539 (fax)
[email protected]
I'm not sure the right Taylor test kit (I still have Ben's), but they'll have what you need.
What others have said is right though. You need to sustain the high levels to effectively kill off the algae and you can't judge 15ppm by the seat of your pants.
Jim
jhm
905-895-4539 (fax)
[email protected]
I believe the Taylor K-2006 is the rough equivalent to Ben's kit. The kit they're selling at Troublefreepools is designed almost exactly like Ben's kit.
Sam_I_am
Dave
Yes. The ONLY flocculant you should use or need is the same as the only algaecide you should use: Polyquat 60%. It's an excellant floc--and it comes in the same bottle as your algaecide.
Otherwise you should NOT be adding chemicals like flocs, clarifiers, algaecides, phosphate removers and all the other GARBAGE pool stores sell you. It's mostly like using an air freshener on a garbage can--it doesn't make it cleaner.
I do NOT recommend adding ANYTHING as a preventative other than chlorine and polyquat.
When you start adding stuff "just in case" you are asking for trouble.
Remember: only TWO things in pool chemistry really matter--pH and chlorine sanitation. Everything else is to help pH and chlorine do their jobs.
Sam_I_am
Dave
Dave, the kit you are referring to, which is sold by Duraleigh, can be found at www.tftestkits.com .
His kit is often mentioned in conjuction with my site, troublefreepool.com, but the two sites are in fact seperate. I have the tf-100 myself and it is a great kit.
HTH.
www.troublefreepool.com
site owner
