Jeff, is there not a diverter valve that lets you adjust the flow between the pool and the spa? The Pool Pilot manifold should be installed after this valve and on the pool side.
Should you install it on the spa side, or before this valve, you need to make sure that you manually reduce the output %, to avoid any damaged that may result from too high a chlorine level.
If you can send me a photo, it may make it easier for me to assist. If it's not convenient to send or attach it through Pool Forum, send it to my e-mail,
[email protected]
