Just chlorinating is NOT working.
I have been dealing with green cloudy water for weeks now. In the past four days alone I have dumped twelve gallons of 6% bleach and five pounds of Trichlor "shock" with absolutely no effect. I'm getting pretty discouraged. I do not have the good test kit yet I am waiting on it so I don't know the levels. All I know is I have spent hundreds of dollars on bleach in the past month with absolutely no results. Please help!!!
Re: Just chlorinating is NOT working.
It's pretty common to waste a LOT of chemicals fighting algae. The bottom line is -- if you don't put enough in to kill it, you probably wasted everything you put in. Algae and slime doesn't actually eat chlorine, but it uses it up. Essentially, in any given 24 - 48 hr period, either the algae loses, or you lose all the chemicals you added!
Your pool has a PF of 9, and bleach is about $3/gal, so assuming you've purchased and used $150/3 or 50 gallons of bleach, you have added 50 x 0.5 (lbs Cl2 per gallon) x 9 = 225 ppm of bleach. If you'd added even 1/3 of that within a single 48 hour period, your algae would be gone.
One possible alternative explanation: you've been buying stale or low % bleach. Discount 6% bleach, that's been stored in a warehouse for a year may be 1% bleach + salt. And, some discount stores are selling low % bleach. That's one reason we often recommend Walmart store brand bleach: it's fresh, it's 6%, and it's plain, with none of the pool-un-friendly goop Clorox has been adding to their branded bleach.
Another alternative explanation: you have zero CYA, have added bleach in the MORNING, have fairly clear water in spite of the algae, and have had sunny days. In clear water, on a sunny day, with no CYA, you can lose 95% of what you put in -- no matter how much you put in! That's why we tell people to dose for bleach in the EVENING.
Post your ACTUAL current test results from an OTO & phenol red testkit. If you've added 12 gallons of 6% bleach, and it's not all gone, your chlorine level will be above what the kit will show, but tell me what color it is (dark yellow, orange-yellow, orange, brown).
I tested this morning and I am getting a dark orange color when i do. All of the bleach I have been using is Wal mart 6%. That was the past two days. No difference. I put 5 lbs of trichlor in last night. No difference. But the chlorine levels are high and i do only add in the evening. Waiting on a good kit to be delivered but the cheap test strips are saying that CYA is 0, but I know how inaccurate those are. So when you say keep levels at 15ppm does that mean AT or above or does it matter?
Your water is truly green, not blue cloudy?
I've had similar issues this year, but my green went away with consistent high chlorine levels. My cloudiness did not and I had to go another route for that.
justlane4
If you truly have no CYA, and it was sunny today, your chlorine would have been all gone by the end of the day. If it was not, you almost certainly have very high CYA levels. If you can get an HTH 6-way from a local Walmart, do so. It has the Taylor CYA test. If not, check your chlorine in the AM. It it's unchanged, and you haven't added additional chlorine . . . then your stabilizer is VERY high.
I'm reluctant to tell you what to do, when I don't know what your levels are. Your pH reading may be accurate IF the CYA is high, but if the CYA=0, then the pH reading is bogus. Chlorine that high messes up phenol red, unless LOTS of stabilizer is present.
Ok the test kit finally came. I added another 5lb of trichlor 48% last night (thats two nights in a row) and took a measurement this morning. All the while my pool is still green and cloudy, by cloudy I mean you can see about a foot down until everything disappears. My readings were:
FC 35
CC 0
pH 7.2
Alk 170
Hardness 180
CYA 60
Please help this is very frustrating.
So if my CYA is 60 then i need to get my chlorine level to 75ppm???
I would start with a single dose of 20 ppm, not 75 ppm. That's about 5 gallons of PLAIN 6% household bleach. You cannot keep using that trichlor + goop blend. True trichlor is 90% or more available chlorine. What every your CYA was BEFORE you added the trichlor, it's a lot more now.
Use bleach, and keep working up your chlorine level till it dies.
One HUGE caution: metals can turn a pool green. Slimey walls on a vinyl pool = algae. No slime? It might be something else. If you have orange iron dust on the bottom of the pool, it can make your water look green.
Check your filter: dead algae is tan; live algae is green; iron is orange or orange brown. If you have iron, instead of algae, you do NOT need huge chlorine doses.
Ok so I'm pretty sure it's the metal. I have very bad rust stains in my house from our water due to a high iron content. When i do backwash my filter it is green at first but turns a brown color. When i vacuum my pool i get a light green color when i hit the light spots but when i go over the heavy spots its very dark almost brown. The sides are not slimy at all, but the bottom can fell a little but more gritty than slimy. When i cleaned it today it looked as if the water was brown coming out of my out flow. I've heard that metal does not get trapped in a filter. What can i us to get rid of it???
Do the CuLator metal removers work or should I use one of the liquid metal removers?
Liquid metal removers don't remove metals; they just keep the metal in a water-soluble form . . . for awhile. The ones made with HEDP are much better than the others, some of which are not at all chlorine compatible.
CuLater DOES remove DISSOLVED metals -- but not stains -- onto the plastic beads. Because of the way they work, they are very slow. You have to use them with HEDP, since the CuLator can only grab dissolved metals.
A metal removal strategy requires getting the metal off your pool surfaces and into the water, and then out of the water and onto your filter or the ground (floccing) or into the CuLator.
Precipitated metals ARE removed by your filter. The brown/orange residue is iron oxide (rust) or similar compounds.
Given that your pool is already cloudy and messy, probably what you need to do is chlorinate, filter, & vacuum till your pool water is clear and clean. Then, you can go back and remove the metals from your walls.
However, I'm puzzled by the fact that your pool is green; usually with that much chlorine, iron will turn orange. Please do all these things:
1. Send pictures to [email protected]
2. Vacuum your pool THOROUGHLY. Clean your filter. Then, do it again.
3. Get a K-2006. You're gonna need it to clean this up.
4. Read the polyquat page . . . then get some, and start using it. It will help with the filtration AND with any algae AND let you run lower chlorine levels, while you are dealing with metals.
Testkit links:HTH 6-Way Test Kit @ Walmart
The HTH kit is a good stop-gap, but it doesn't include the DPD-FAS test, which you WILL need.
He states above that his K-2006 arrived and his levels in post #7 are with that kit.
Ok sorry it took so long to reply. It most certainly is algae.
My filter was not filtering anything so i read another post about how your sand can get channeled. It said to stick a hose down into your filter and run it until the water is clear. It also said to do it for around fifteen minutes or so. I ran it for over an hour repositioning it every ten minutes or so. It was still spewing out green and brown bits but was much clearer so i tried to vacuum at first it seemed to be going well but about a third of the way through it started flowing back into the pool like it wasn't filtering again. I tried backwashing and got some very green water and tried filtering again but it was just going straight through. The nasty part is that there are chunks not pieces CHUNKS of green and brown algae mixed in with the filter sand I tried to get most of them out but there was just so much.
So do i need to replace the sand? I just did last year but left it out all winter and didnt use any winterizing agents to close it. Or should I just keep trying to clean the sand I have with the hopes that it will finally come clear?
On a small filter like that, it sounds like the easiest solution would be to replace the sand, given that the filter is already open.
You *could* clean it up by adding bleach via the skimmer, or keeping a chlorine tab there. But it would take a while.
Meanwhile, do NOT let your chlorine levels in the pool drop. Pour bleach 'around' the pool, if the water is not circulating.
Ok so Saturday I cleaned every bit of sand out of my filter and sifted through it and rinsed it with water until it ran clear so it is virtually as clean as year old sand can be. I added an entire quart of the polyquat algaecide as you suggested and as the directions instructed (11-17 oz per 10,000 gal.) on Saturday. Sunday evening I added three gallons of 6% bleach as well as 32 oz of muriatic acid to lower pH which was over 8 at the time. As of Moday evening after work these are the numbers I am getting.
FC= 7.5
CC= 0
pH= 7.7
TA= 150
CYA= 42
I have sent pictures of what the condition of the pool is through the email you provided. I will continue sending measurements and pictures each day until we can figure this out. Can you let me know what I need to do as of today?
I'll post the pictures shortly; the pictures make it completely clear your problem is definitely algae.
I have once, maybe twice, encountered algae that was extremely resistant to chlorine. (It may, or may not have been resistant to other things -- I didn't try!). In one case, it took around 40 ppm (roughly, this was before DPD-FAS kits were available) of chlorine to have an effect, and about 60 to kill it. Stabilizer was in the 40 - 60 ppm range.
1. If you have any more acid, lower the pH to around 7.4
2. Get 18 gallons of plain 6% bleach. (~80 ppm of chlorine)
3. Run the pump 24/7
4. Tomorrow, starting as early as you can, begin adding bleach 3 gallons at a time, every 1/2 hour.
5. Continue adding till you see a color change in the algae, and then add 1 more dose.
6. The next morning, add 3 more gallons.
7. Make sure that you have at least 12 gallons on hand the 2nd evening.
8. When you get home, the 2nd evening, add 3 more gallons if there is the slightest hint of a green color. Test, and verify that the chlorine is still high (OTO orange) - if it is not, add 3 more gallons.
9. Then and then BRUSH the pool completely.
10. Wait 1 hour, and test -- if the chlorine is not high (OTO orange) add 3 more gallons.
11. Keep an eye on your filter, and clean it as soon as you notice flow dropping off. There is going to be a LOT of dead algae to filter out.
You don't want to go further than you have to; it may bleach your liner somewhat. When I've done this, I've been working on concrete, not liner pools.
Also, if you can take pictures as you go (each 1/2 hour) that would be great. It would help lots of other people get a clear idea of what they are looking for, when chlorinating algae.
WOW! That's some green pool. Can you say YUCK! Do take pictures as Ben suggested. You're gonna be amazed to watch the improvement as the bleach is added. It will be dramatic!
Ok I've done like you've asked and applied the bleach as you instructed. Pictures have been sent. I'm not really seeing much of a difference yet though. I'll do another three in the morning and send pictures before I leave and after I get home.
Yeah. I emailed you. Please add 3 more in the AM and take more pics.
I'm surprised that 36 ppm is having no effect. Oddly enough, we have two other similar threads running like this.
Here's the one with the most info:
http://www.poolforum.com/pf2/showthread.php?17752
That guys story sounds awfully familiar. I had a sparkling pool as of May 22, my daughters birthday party. It got cold for a few weeks after and I let it slip. It's been green ever since. i even have spotted a frog or two before as well. I'm out of town a bit so snakes and frogs are not that big a deal for me.
justlane4
I'm not scared of frogs but just wouldn't want to swim with one. Snakes ----- would be a BIG deal to me. Fortunately, we rarely see one. I am scared of them!
Ok sent new pics from after work. Maybe a little greener but not much.
