Re: Ascorbic acid surprise.
If you have clear green, that's probably the copper precipitating out. You can log out to read through the Metals forum until your registration is upgraded, but I'll ask Marie (the resident stain expert) or Ben (the other expert) to pop in and see if they can help.
Curious --- why did you add the thiosulfate?
aylad
Ben who? ;)
Added sodium thiosulfate to burn out remaining 3 ppm chlorine. Thought that was part of the procedure else aa burns off the chlorine.
Ascorbic acid does not work the same on copper as it does on iron. It does seem like te ascorbic acid lifted the stain off the pool surface and is now in the water. You will have to get it to oxidize out to stain on your filter, but I am not familiar with cartridge filters, or copper stains. My advice would be to go on the Jacks Magic website. They have a lot of info about stains. They will probably tell you how to get rid of the green water using their products. Please keep us informed.
sweep49
One more thing, I added a Culator on Monday and this morning (Wednesday) it had turned blue indicating that it was binding copper per their literature. At this point some stains have lifted but not a miracle yet.
If the Culator is turning color, then it looks like it's working--please, before you get rid of it, take pictures--both of the outside and inside. We're still researching this to make sure it does everything it claims to, and all the documentation we can get helps! If you can take pics, send them to [email protected], and reference this thread, or at least your username.
Thanks!
Put the filter back on and added a 3rd quart of the Pink Stuff last evening. Water is clear and colorless this morning. Little improvement to the major stain areas except for the top step where I sprinkled aa directly. Will take some pictures of the stains and Culator later. Now to work on getting FC and pH back in order.
BTW I looked at Jacks Magic website and yes they have some stuff for removing copper stains but it would be expensive. Pool contractor said he would drain and acid wash the pool for $300 + $80 for refill water; cheaper than Jack's treatment. Don't want to do that but when you see the stain pictures you will understand my frustration.
You may already know this, but in case you don't ------- acid washing removes the top layers of your pool's surface making them more porous and vulnerable to staining.
I noticed that your calcium is a little low for a gunnite pool. It should be at least 250. Sometimes ascorbic acid will lower calcium too, so you should check it again. You may want to try putting ascorbic acid in a sock so you can concentrate it on the stain. Just rub it where the stain remains to see if it lifts. let me know if it works, thanks
Thank you for your comments. I will get some calcium into the pool soon. I did read about the downsides of acid washing, but the stains are pretty ugly. I have sent pictures of them to the forum's email address and hope they will get posted for further consideration.
Haven't received any pictures at [email protected] . . .
While your calcium is a little low, I'd hold off on adding any now. You're thinking about removing FAR more calcium with an acid wash, then you would with a year of slightly low calcium pool water.
But, get your pH up to at least 7.0. Then I'd recommend 3 things:
1. Try ascorbic acid in a sock on a badly stained area.
2. Also try "Iron Out" in a sock on a similar area.
3. And finally, tell me what Jack's chemical they are recommending: you may be able to get some THAT chemical in a bagged version somewhere, and try that before you get a bunch.
Good luck!
Thanks for the advice; I have raised the pH to 7.2 and FC to 6. There was no specific recommendation for Jack's chemicals, just that I visit their website. Jack has a treatment for copper stains but as I read it, the regimen for "the Copper and Scale Stain Stuff" would cost well over $200 and take the pool off-line for weeks. Don't think I want to do that.
I have resent the pictures to the gmail address.
I'm not sure what I'm seeing.
If the colors of the FIRST 2 pictures are correct, you may have copper staining + plaster mottling.
In the second 2 pictures it looks ONLY like plaster mottling, to me. The fact that you mention "brownish stains" in your first post make me think you ONLY have plaster mottling.
Plaster mottling is a defect in the plaster, possibly accentuated by water conditions. It's NOT a stain. Acid washing will tend to even the surface coloration, but at the cost of a more porous and abrasive exposed surface.
Here are some resources:
http://www.poolhelp.com/handouts/oB_...%20Handout.pdf
http://poolhelp.com/handouts/oB_Conf...%20Handout.pdf
http://www.poolhelp.com/npc_cal-poly.html
Ben I am a bit stunned by your comment and a little overwhelmed by all the attached content. I have perused the attachments you provided and am struck that there may not be a "good" solution to this problem, if it is plaster mottling, other than re-plastering. Is my inference correct?
Regarding the pictures the color of the stains on the steps and the swimout (photos 3 & 4) are better depictions of the actual color of the bottom stains, which are influenced by the depth of the water through which they are photographed.
This problem became pronounced about a week after I put a copper algaecide in the pool. It was 1 quart containing 13% of a copper compound. This would have introduced about 3 ppm of copper in a 20k gal. pool I think. I have paused to wonder if that's enough copper to stain/mottle the entire pool to one degree or another.
Thank you for considering my problem.
Plaster mottling is usually an appearance problem, not a function problem. Whether that means resurfacing or not is up to you.
However, a lot of plasterers don't guarantee mottling won't happen. And there's a LOT of debate about why it occurs (workmanship vs materials vs pool chemistry).
Copper may generate blue, blue-green, or even black stains . . . but not brown.
You can try putting Vitamin C on the discolored areas, as well is Iron Out. If it's copper, one of those will lift it off.
