Re: I think I have a leak :(
Send pics to [email protected] and reference the URL of this thread so they can be matched up and posted in the right place.
Thank you so much! I sent the photos. I have since found quite a bit of water on the other side of my fence and realized I lost about an inch of water since yesterday. So frustrated :(
There's a chemical called "Find A Leak" that you can use to exactly locate the leak. Turn the filter off and let the water settle. Then pour some in where you think the leak is and wait. The dye should collect at the leak point. I was looking for one leak last summer, and not only found it, but one below it I didn't know about!
If the pool is vinyl you can patch underwater with vinyl patches (I use a hunk of liner) and Boxer brand glue. If it's concrete there is underwater epoxy. If it's in the plumbing, you simply have to find it and fix the pipes.
Thank you so much :) If the leak is in the pipe between the cleaning system and the pump in the pool house (under the concrete) - where would I poor the find a leak? Thank you again!
If it's in the plumbing, the Find A Leak is not going to work. You need to hunt for the leak and may have to dig up the line.
Thank you! I think it is in the line and not the concrete pool. Only because when we turn the pump on it comes out of the concrete in the pool house :( ANd there is sitting water now around the pool house and we have lost almost 4 inches of water in 2 days. Ugggg.... I cannot believe a pool person cannot get out here on an emergency call. Frustrating! Thank you again
Probably they'll have to dig up the line and repair the break. These days, pool plumbing mostly uses PVC pipe and Schedule 40 glued-on fittings (Schedule 40 is a standard for plastic pressure pipe). Finding the break is the tough part. Fixing PVC is pretty easy. If you have a concrete deck you have to cut through, that's tougher.
If it's simply a pipe, any plumber should be able to repair it.
Ashley711
Indiana is seasonal pool country -- very seasonal. Pool businesses struggle to keep employees over the winter, so they'll have some come summer. But there's no way for them to carry enough employees in Nov, Dec, Jan, Feb, & Mar to have enough to meet demand in May and June.
. . . membership upgraded.
Thank you all for your replies. My husband and I decided to just start digging in the yard - lol. Probably a bad idea, but we are just frustrated. So we started at the pool house and dug a bit until we found PVC. Right at the concrete foundation water was just streaming out. We are sure it is a pipe under the concrete in the pool house. We found large tree roots wrapped over and under a few pipes. In looking in the pool house - you can see where this area of concrete has been cut out in the past. I think we could probably fix the leak if we can get someone to break the concrete up for us - softly haha without causing more damage to the pipes.
See if there's a Home Depot Tool Rental close to you. They rent concrete saws and electric jack hammers. If you are up for it, that'll save you some money.
