eyeball faceplate cracked
When shutting down my vinyl liner in ground found cracked face plate for the eyeball. I was blowing out the lines and installing the plug air bubbles were coming out of the crack. Continued to tighten the plug and got it to stop.
I have read posts that say how to replace the faceplate. Wondering how the feed line attaches to the female thread base. There are three screw holding the plate to the wall. It looks like the female thread base is part of the plate and I'm concerned that this to may be cracked. The pool is over 20 years and The liner has been replaced .I have always done my own maintenance upkeep on the pool. What can I expect to encounter trying to replace it.
Re: eyeball faceplate cracked
I have pictures but can't attach them.I don't have a manage attachments button or can't find it. The posting permissions says I may not post attachments. How do I do post the pictures? Thanks for helping
Alternatively, you can email the pics to [email protected] and reference the URL of this thread. Can't promise you how quickly the pics will be added to the thread but I'll keep my fingers crossed for you that Ben will have time soon to be able to do it for you soon! ;)
Here's what you have, I think:
https://lh4.googleusercontent.com/-f...400/sp1408.JPG
You'll need to unscrew the plug, and then replace the face plate.
I really, really hope you used pipe dope, and not some sort of sealant on the plug. As you can see, the plug screws into the body of the SP1408, and not the plate. You can't remove the plate without removing the plug. Also, there's a significant risk of the liner shifting when you remove the plate. If it does, you won't be able to re-install the plate. Consequently, you must NOT drain the pool to do this work: if anything, you need to RAISE the water level, so the liner will be held tightly in place by the water.
Finally. . . the plug you used isn't really intended to make an absolutely water tight seal. It's a vacuum safety fitting, used to plug lines with suction on them, to prevent entrapment. They are common on commercial pools which may have in-wall vacuum ports.
I've replaced two or three of those plates in our pool. I didn't lower the water level and replacement was easy; no liner shift issues. :)
I don't have enough experience with liner pools to know how likely liner shifting is; I just know that it can happen, and can be a real problem if it does.
Jumpin in here. Is that a touch of algae around the face plate? If so, a toothbrush cleaning may be in order around your others.
Thanks for all the input . The plug has pipe dope on it and it is old. I removed the plate and replaced it ,no problems. I installed new plugs using a Teflon type dope, no leaks with 5 lbs air pressure on the line.
