kjsmom
I have a 23,600 gal vinyl liner inground pool. On May 1st Leslie's tested my water. Results were:
FC: 1
pH: 7.6
Alk: 80
CYA: 30
That day, I added 5 lb 10 oz of CYA. Today, 5/9, Leslie's tested again:
FC: .5
pH: 7.8
Alk: 100
CYA: 35
My test results, with my drop kit, indicate pH of 7.6 and Alk of 80. I cannot test for CYA. My question is, would it be possible that the CYA is still not dissolved? According to Michael's calculator, 5lb 10 oz of cya should have raised the cya 30 ppm, to 60, not 35. The water temp is 71 -- not too bad. How subjective is the CYA test? I've read that a dot has to disappear; is the cya test predicated on a color change? Could the results be off by 30ppm? That seems to be alot for cya. Thanks.
PAT
