You'll get better results if you raise the pH and dose chlorine to 15 ppm with bleach. Leave the cover partly on, to reduce solar loss.Originally Posted by Truckman
I wouldn't vacuum to waste, unless stuff is blowing through the filter. But, if it is, that indicates that your filter is not operating properly, and needs attention. It may be too small for your pump, or be filled with coarse sandblast sand, or simply need to have sand added. Given that it's an AG pool, you may have all three problems. AG pool filters are almost always undersized. If you have a two speed pump, the quick fix is to run on low speed, which typically moves approximately the correct amount of water for the filter, and allows the filter to actually filter the goo out, instead of the goo being forced through the sand by the excessive pressure and flow.
Ben
