Re: CYA in a sock
My experience, for what it's worth:
Monday, 6/28, 06:30
ph 7.6
CYA 30 (consistent with previous tests over the past 4 weeks)
CYA goal 50. Per Pool Calculator, add 946 g CYA.
The CYA I use is mfg'd by Seaboard, 100% cyanuric acid, granular. I added 500 g slowly into the skimmer, basket removed, made sure all product was granules, no clumps. The 2-speed pump ran on 'high'. The CYA swirled in the pump pot for 15 - 20 minutes until it had all gone into the filter. At that point I set the pump to low and left it running.
According to the Pool Calculator, 500 g CYA in my pool would decrease pH by .2 and increase CYA by 11 ppm.
Tuesday, 6/29, 08:30:
pH 7.4
CYA 45
I can readily accept the difference in test results from the calculated expectation because a) the water volume can ever be just a close guess and b) variations in the 'endpoint' of the CYA test.
My past experiences with adding CYA product have been similar: it dissolves faster than what I had read and it's measurable within 24 hours.
