Thread: Calcium Deposits?
    Jun 2010
    Louisiana
    Default Calcium Deposits?
    WoW, i am filling this forum up with my posts.... .
    Anyways, I have always kept my pH levels on the low range in Salt water pools, I have been told to keep it at 7.1 range and I do that.
    But i am having a problem with what it looks like Calcium deposits are that developing on the walls of some of my dark bottom pools. I take care of every single pool the exact same, and some dark bottom pools do not have it but others do. I have been taking care of a pool for nearly 2 years then out of the blue these calcium deposits started showing up. I can brush them off with a wire brush or a pumice stone and they come right off. But they keep appearing a week later. I have taken a few pics and curious to hear what you guys have to say.
    They mostly develop in the spa (the spa is connected to the pool) then they start going into the pool itself.
    http://i35.photobucket.com/albums/d1...Picture011.jpg
    http://i35.photobucket.com/albums/d1...Picture010.jpg
    http://i35.photobucket.com/albums/d1...Picture009.jpg
    http://i35.photobucket.com/albums/d1...Picture012.jpg
    http://i35.photobucket.com/albums/d1...Picture008.jpg
    Chemical readings (Salt Pool)
    FC 4.5
    pH 7.3
    TA 79
    CH 240
    Cya 85
    I have been told that I need to keep the CYA levels between 60 -80 is that right for salt generators?
    Last edited by PoolDoc; 06-29-2010 at 07:29 AM. Reason: fix subject spelling so it 'searches' better ;-)
    Jun 2010
    Louisiana
    Default Re: Calcium Depoists?
    I even went to the extreme and back washed the spa into the pool and acid washed the spa some, took all of the deposits off but they came back a few weeks later. :\
    I only did this twice, i know acid washing shortens the life of the plaster.
    I'm gonna email a guy who recently registered, and who knows WAY more about this than I. Maybe he'll answer. Or not. He manages a pool route with over 10,000 pools.
    Ben
    "PoolDoc"
    PS: there's not a simple answer to this problem!
    Jun 2010
    Louisiana
    The pools that have this problem were all built by the same builder. Something tells me it's the way they mix the calcium to make the plaster. Just a shot in the dark though.
    waterbear's Avatar
    St. Augustine, Fl
    Quote Originally Posted by Jasheon View Post
    possibly calcium nodules
    http://www.poolhelp.com/onBalanceCal...leBulletin.pdf
    Yeah. Poolhelp is Que's site -- he's the guy I mentioned above.
    Ben
