Thread: Where to get 31.45% muriatic acid?
    Jun 2010
    Default Where to get 31.45% muriatic acid?
    I've been using quite a bit of acid as I'm lowering the TA in my pool. I originally had a supply of 31.45% (20 degree Baume) provided by my former pool service, but now I'm buying my own and can only seem to find 14.5% acid -- that's what Lowe's and Home Depot sell.
    Does anyone know where I can find the stronger stuff? I live in Tucson AZ.
    15000 gallon Pebble Tec with cartridge filter. Popular watering hole for local quail, doves, squirrels, &c, &c. Congregation of bees near the overflow outlet is a capital offense!
    sturev's Avatar
    sturev is offline Registered+ Thread Analyst sturev 0
    May 2010
    Default Re: Where to get 31.45% muriatic acid?
    Try the smaller hardware stores. I just bought 31.45% from my local Do it Best. It probably wasn't the cheapest, but hey, the nearest Big Box Store is 40 mins away...
    Evan S.
    AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
    Also check the pool supply stores. They generally carry the 'good stuff".
    sturev's Avatar
    May 2010
    Also Paint stores should have it too...
    Evan S.
    Jun 2010
    Talking Re: Where to get 31.45% muriatic acid?
    Thanks y'all. I found it at a hardware store / lumber yard here. Now that I know the kinds of ripoffs the pool supply stores engage in, I avoid giving them my business whenever possible :-)
    Don't know where you are in the country, but if you have a Tractor Supply Store nearby they have it for the cheapest price around here...
    Quote Originally Posted by laughingboy View Post
    Sometimes they have the best prices on acid AND there are some things that you can only get at a pool store so don't cut off you nose to spite your face. In many areas liquid chlorine and acid are cheapest at the pool store.
