Hi Brian and welcome. Glad you got a good test kit. That is going to make everything much easier for you.
If you could still see the black dot on the cya test when the vial was full, then that means your cya is less than 30, not more than 30.
What is in "Chlor-Brite" --- meaning ingredients?
If you just shocked the pool yesterday, the cloudiness is probably due to dead algae that needs to be filtered out. If it was my pool, I think I'd go ahead and keep it at shock level for another day and also run the pump 24/7 while trying to clear this up. Not sure about the floating white stuff. Let's give it a day at high cl and lots of filtering and see what that does for you. If still cloudy after a few days and still no CC, you might try adding a little DE to your sand filter. There is a stickied thread about that in the pool equipment section of the forum.
Also, your calcium hardness is pretty high. I wouldn't use any cal-hypo in this pool.
Hope this helps. Repost if you have more questions.
BTW -- Al (Poconos), one of my fellow moderators also lives in NE PA.
