Results 1 to 10 of 14
Thread: Different types of CYA??
    Default Re: Different types of CYA??
    I used to sell the intex pools and recommended starting them with a set amount of dichlor as a fast and easy way to get the CYA up to speed and then switching to liquid chlorine (bleach). Dichlor is extremely fast dissolving and raises the CYA 9 ppm for every 10 ppm of chlorine added. Given the ease and speed of this method it is relatively cost effective.
    The easy set (donut) 12 x 30 pools holds about 1500 gallons while the metal frame holds a bit less than 1700 so if you decide to go this route you would need to chlorinate with dichlor granules until you have used a pound total and then switch to bleach. Once the pound of dichlor has been used your CYA will be in the neighborhood of 40 ppm and within the recommended range of 30-50 ppm. If you find that the pH is dropping from the dichlor then add between 1/4 to 1/4 cup borax to bring it back up. Safest way is 1/4 cup at a time, wait a day ,and retest pH.
    EDIT: almost forgot, 1 tablespoon dichlor (1/2 oz.) will raise the FC in this size pool about 1 ppm for the metal frame and closer to 1.5 ppm for the easy set. Not exact but close enough for government work!
    Jun 2010
    British Columbia, Canada
    Talking Re: Different types of CYA??
    Hi,
    Thanks CarlD and Waterbear... Very useful info for the newbie. I have an Intex metal frame that holds 1718 gal at 90% capacity. With the dichlor, since it is a powder, do I still have to do the sock method near the drain or can it go directly into the pool? Pardon me, if some of my questions seem silly. As stated before, we figured this was an okay way of seeing if the pool thing was something that I could actually do! I have no idea.
    Cheers
    Carrie
    It depend on how much Di-Chlor you add. However, while your chlorine will go up and down as it's used up, your CYA won't go down until you drain your pool. CYA doesn't get used up.
    Jun 2010
    Hi,
    Since the pool has no water in it yet, do I have to wait till all of the numbers are where they should be before boys can go in? I will test the water prior to filling and post numbers to see what I need to do..
    Many thanks,
    Carrie
    No. If it is a fresh fill, it should be clean and fine for them to get in. But, get some chlorine in there ASAP. I know they will be anxious to get in so let them in. EXCEPT if the pool sits for a day or two in hot sun with no chlorine, then I would NOT let them get in. It doesn't take long for trouble to start brewing in an unchlorinated pool on hot sunny days.
    Jun 2010
    Red face Re: Different types of CYA??
    Hi,
    Thanks for weighing in Watermom.. Just came back from pool store. I purchased a product called Boom by Sani-Marc. It is stabalized chlorinating granules that is fast acting with neutral ph. Not suppose to effect PH levels. I was told that I could put directly in the pool and they would dissolve fast. I guess once I use this as per Waterbears post, then I would make the switch to the bleach? Contents of product:
    Sodium Dicloro-s- Triazinetroine 100% and available chlorine content 62%.
    Carrie
    Quote Originally Posted by drako4 View Post
    Hi,
    Carrie
    That is dichlor...use only 1 lb total over the next weeks to maintain the FC at about 3ppm then switch to bleach. Once you have used one lb of the dichlor your CYA should be perfect. You can just broadcast the granules over the water, it will be dissolved before it hits the bottom.
    It actually can have a slight effect on pH because it is very slightly acidic and the reaction when chlorine gets used is acidic. Therefore, the net effect of using it is acidic. Once you switch to bleach you still have the acidic reaction of the chlorine but the bleach is alkaline and so the net effect is bascially pH neutral.
    Hi,
    Cheers
    Carrie
    Most pools are not filled to 90% which is why I said a bit less than 1700 gal.
    100% would be to the very top and most pools are filled to about 6" below. 90% would be 3" below the top.
    I always calculation volume by water depth, not pool height. I figure a 52" high pool is actually 4'.
    Precisely!
