Results 1 to 10 of 16
Thread: Hayward CL200 Automatic Chlorine Feeder
    Default Re: Hayward CL200 Automatic Chlorine Feeder
    Quote Originally Posted by ksturge
    As interesting as the rum threads are...can I ask a few questions about the CL200. I have one - doesn't seem to restrict any flow, but I trust what is said on this forum so could someone lay out the problems with using this product? One problem I've had in the past is that my heater had to be replaced after only 4 years and I'm wondering if it had anything to do with this chlorine feeder. The inside of the heater was a rusted out mess.
    Is the feeder plumbed before or after the heater. It should be after. If it is before the low pH of the trichlor could cause damage to the heater.
    I'm in the process of keeping the chlorine levels very high to get rid of leaf stains at the bottom of the pool. I thought leaving the chlorine feeder completely open and full of pucks would help this problem? Maybe I'm wrong and causing more harm than good.
    What is your stabilizer level? The biggest problem with using trichlor or dichlor is that it causes your stabilizer (CYA) to constantly rise and that requires you run the pool and shock the pool at higher FC levels. The reasons are somewhat technical but you might want to check out this thread for some more information on what levels to run your pool at.
    http://www.poolforum.com/pf2/showthread.php?t=365
    Most of the folks on this forum add CYA manually to a level of about 30-50 ppm and then run their FC and shock levels according to the chart in the above thread by using bleach ( which is non stabilized chlorine, sodium hypochlorite). This is probably the easiest and most economical way to chlorinate your pool.
    Take some time and read through the stickies on the forum and read everything on the sister website www.poolsolutions.com and you will soon understand the BBB method of pool care (Bleach, Borax, and Baking Soda)
    If you have any questions just start a thread in the appropriate heading and you will get all the advice you will need.
    If you haven't got one already DO get yourself a good drop based test kit that will measure FC, TC, pH, ALK, CAL, and CYA. Do not use test strips...they just don't have the accuracy for maintaining a pool.
    Hope this is helpful
    Illinois
    Thanks - I've ordered Ben's test kit. When it comes I'll be able to be more accurate. The feeder is after the heater so maybe that wasn't the problem.
