Results 1 to 10 of 13
Thread: Progress finally, or The TA battle...
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Default Re: Progress finally, or The TA battle...
    CH of my fill water is 120ppm, I tested it this morning. I think a aprtial drain will be worth the effort. Since I won't be dealing with the added complication of new plaster, dropping TA after re-fill should be a litte easier, right?
    5.5 more cups of muriatic last night, TA down to 110 (uncorrected for CYA). I may have finally broken the plateau. Beating on it again this evening. The waterfall really helps with aeration, It brought me from a pH of 7.0 to 7.3 in about 2.5 hrs last night, running full pressure.
    Quote Originally Posted by steveinaz View Post
    Next question, what is the TA of your fill water? You will need about a 50% replacement to get your CH in range from around 700 ppm. You might even need a bit more than that.
    Southern Arizona
    Fill water:
    TA=170ppm
    CH=120ppm
    New numbers this morning:
    FC=6
    CC=0
    TA=90 (uncorrected)
    PH=7.5
    CH=680
    CYA=90
    Salt=2600
    Water tmp=83 degrees
    CSI= -.19 (balanced)
    BEGIN CHAPTER 2, metal stain removal...
    Fill water:
    TA=170ppm
    CH=120ppm
    FC=6
    CC=0
    TA=90 (uncorrected)
    PH=7.5
    CH=680
    CYA=90
    Salt=2600
    After you do the stain removal, if you do a water change to lower your Ch you will be removing much of the iron tainted water from your pool and reduce the risk of restaining. Untill you do you will need to add a maintenance dose of sequestran weekly to monthly.
    Bad news is, once you do the water change you will have to lower TA again! (And also adjust, salt, CYA, etc.)
    Too late now but, IMHO, the best way to do all of this would have been the stain removal, water change, and then lowering of TA.
    Southern Arizona
    At least I'm all practiced-up
    I was thinking the same thing, but if nothing else, it was a learning experience. I'll likely just do a 100% drain this fall, The guy at a local Leslie Pool told me he has seen no iron in fill water for people on city water, so hopefully the stain lifting will be a 1 time thing--and it really is quite minor, as far as how light the stain is, I'm just picky. He told me to bing a sample in, and he'll test it for metals.
