Closed Thread
Results 1 to 10 of 19
Thread: Can I use sand from Lowes
    Lexington, Ky
    Question Can I use sand from Lowes
    I need to change my sand out this year and was wondering if I could buy cheaper sand. I know I can get it from the pool store. They want $9 for 50lbs. and I need 4 bags. I was hoping to find it at Lowe's or Home Depot, but I'm not sure what kind of sand to get. Can someone help me out with this.
    Thanks in advance. Wendy
    Default Re: Can I use sand from Lowes
    If you can find labeled filter sand from either of those places, that will be find.
    But, do NOT use play sand, sandblast sand, masonry sand, or any other kind of sand. Those sands will, variously, be too coarse, or else include fine particles that will damage your valves
    Ben
    "PoolDoc"
    duraleigh Guest
    Why do you need to change your sand? Sand last for many years?
    If you do so anyway...you need swimming pool sand....Lowe's sand is filthy.
    Lexington, Ky
    I have to change my sand because I didn't properly close my pool down and I have a great big oak in my backyard that loves to drop all the leaves in my pool. and has done so for three years now. Last year I had a difficult time cleaning my pool, so i figured I would need to change the sand out this year.
    Duraleigh is right -- you shouldn't assume that your sand needs replacing. It may be the wrong sand, or there may not be enough, or it may be gummed up. But you shouldn't replace just because it's been there for awhile.
    Ben
    "PoolDoc"
    Lexington, Ky
    How would I know if I need to change my sand or not? My pool is VERY green right now with a lot of particles floating around. I just put 20 bottles of the small bleach to kill some of the algae and I'm running the filter. Should I go ahead and buy some algacide or wait until the bleach has some time to work. Thanks, Wendy
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Since you just put new sand in it last year you probably don't need to replace the sand. This may sound like a silly question to a lot of people, but are you backwashing?
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    Lexington, Ky
    I haven't put new sand in it since I bought it in 2003. This will be year 4. It seems I have to backwash it all the time. Which was another reason I thought I should replace the sand.
    Not an expert on sand filters but I know that they sell filter sand cleaners. Perhaps your sand just needs cleaning?
    Lexington, Ky
    How do I clean my sand?
Closed Thread
  1. Sand Filter dumped all the sand in my pool
    By ib_gman in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2012, 01:16 AM
  2. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 11:41 PM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  4. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 01:01 PM
  5. Salt from Lowes
    By estermer in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-29-2006, 08:49 PM
