Duraleigh is right -- you shouldn't assume that your sand needs replacing. It may be the wrong sand, or there may not be enough, or it may be gummed up. But you shouldn't replace just because it's been there for awhile.
Ben
"PoolDoc"
Ben
"PoolDoc"
How would I know if I need to change my sand or not? My pool is VERY green right now with a lot of particles floating around. I just put 20 bottles of the small bleach to kill some of the algae and I'm running the filter. Should I go ahead and buy some algacide or wait until the bleach has some time to work. Thanks, Wendy
Since you just put new sand in it last year you probably don't need to replace the sand. This may sound like a silly question to a lot of people, but are you backwashing?
Sherra
Kershaw County South Carolina
(previous AG pool owner)
I haven't put new sand in it since I bought it in 2003. This will be year 4. It seems I have to backwash it all the time. Which was another reason I thought I should replace the sand.
Not an expert on sand filters but I know that they sell filter sand cleaners. Perhaps your sand just needs cleaning?
How do I clean my sand?
My bad...I got you mixed up with another thread where someone was changing their sand every year.I haven't put new sand in it since I bought it in 2003.
But Waterbear did give a good idea of cleaning the sand. Leslie's carries "sand filter revitalizer" for $15.99/qt on their web site. You can get the same type of stuff (sand cleaner/revitalizer/etc.) at any pool store. You just pour it into your skimmer while the pump is running (or whatever other directions the bottle might say). You MIGHT even be able to find some at Home Depot/Lowe's/Ace/Wal-Mart/Sam's/Costco/you get the picture.
Sherra
The directions are on the bottle of filter cleaner. I know that aquachem, glb,and robarb make them and I am sure other companies do as well. Once again I am not a sand filter expert (use cartridge myself) but my understanding is that organics will build up on the sand after time and lead to clumping and channelling of the medium and reduced filtratration. I assume it is a similar process to soaking a cartridge in an acidic degreaser. From the aquachem website they give these instructions for their product:
"Sand Filter
Backwash first. Then clean the filter sand with AquaChem Filter Cleaner as follows. Close the valves into and out of the filter. Add the product full-strength to the filter top through the inspection port, anode port, sand fill or pressure gauge hole (whichever is applicable). After 1 hour, open valves and backwash the filter thoroughly. Resume normal operation."
Some of the sand filter owners on here might be able to advise you better on the process.
If you "feel like you're backwashing all teh time", should that not be an indication that your sand IS in fact doing it's job?
I'd worry if I DIDN'T have to backwash......
You should backwash when your pressure changes by about 5 lbs.
If you want to get your water crystal clear, you may have to do teh following:
First off, get the algae out and the pool vac'd clean as you can, if the water is foggy/dull, put in some clarifier or floculant - this essentially bunches the fine particles that the filter is unable to get individually. This doesn't always help get them out, but it does drop them to the bottom, to get them out, put 1-2 cups of DE into the skimmer, wait 5 minutes - pressure should rise 3 lbs, then vacuum the pool. With DE you will need to backwash about twice as much as without.
Hi, Wendy,
I think this thread is getting off track. I'll bet if you put enough Clorox in your pool, your water will clear up and you won't have to do a thing to your filter except backwash it.
Now, we can't tell you how much is enough unless you post up some numbers for us. We need FC, CC, pH, Alk, and CYA. If you can't post those, get to Leslies or Walmart or wherever and get a kit that will.That green is still algae and your filter won't kill it....Clorox will.My pool is VERY green right now with a lot of particles floating around. I just put 20 bottles of the small bleach to kill some of the algae and I'm running the filter.
If it were my pool, I'd drop all thoughts of my filter and kill the algae in the pool. THEN, your filter will clean your pool.
Skip the algacide....you need Clorox.![]()
