Re: Can I use sand from Lowes
Where is mwsmith's post? I just added a quart of muratic acid. The bottle tells me I should add 1 quart per 20,000 gal. every 12 hours. I don't know how many gal of water a 27' round pool holds. I guess I could call the pool place and they could tell me, unless you know off hand.
As far as my CYA, my tester only goes to 30 and I could still see the black dot at the bottom clearly, so it would have to be a lot lower than that. I could take some of my water to the pool place and they could test for me if it's that important.
Thanks for helping me out. Wendy
you pool is 17,123 gal at 4 feet full
Easy to figure out (this is using inches)- 3.14xRxRxH/231
3.14x162x162x48/231=17,123
