Re: Should I upgrade my filter?
Hi Tricia,
There are a number of timer devices on the market which you could install to run the pump while you're on vacation. Some are used for pumps that are hard-wired into the box and, if I remember correctly, Intex pumps are plugged into a protected outlet. For that, you can get an indoor/outdoor timer like the ones that run exterior Christmas lights, for instance.
You may want to go with a different pump and filtration setup in the future but Al gave great advice: for now, use what you have, learn all you can about testing and balancing the water, and look at a new filter only if the existing one just doesn't cut it. Spend your money on the vacation
