Thread: Shot glass method doesn't work with DPD?
    May 2010
    Thumbs up Re: Shot glass method doesn't work with DPD?
    Quote Originally Posted by Poconos View Post
    Dilution works with any chlorine test. The OTO test has an upper limit so maybe that's why it was stated that way. DPD goes a lot higher. I do take exception with the tap water comment. Many municipalities chlorinate their water and that can mess up the results. Should use distilled water.
    Thanks. I also wondered why Taylor suggests tap water, though the dilutions they suggest would only add a portion of the measurable Free Chlorine, skewing the test upward by perhaps .5 to 1 PPM FC. That's not too much if someone is diluting because chlorine exceeds the test's 5 PPM upper limit, but it does introduce error.
    Quote Originally Posted by waterbear
    FWIW, if you are going to spend the money on a DPD test kit like the K-2005 you might as well spend a bit more and get an FAS-DPD kit such as the K-2006.
    No argument from me! I was thinking of the shot glass / dilution method in the context of a pool owner's ad hoc attempt to measure high chlorine without immediate access to the FAS-DPD test, say, when fighting algae and waiting for their kit to be delivered.
    I have never come across anyone who said you cannot do dilutions with DPD [...]
    Thanks for the clarification. I just wanted to be sure.
    16'x29' free-form 14K gal IG gunite pool; SWCG & sodium hypochlorite 8.25%; Hayward SwimClear C4025 cartridge filter; Hayward SP3202VSP TriStar Variable Speed Pool Pump; custom test kit based on Taylor K-2006C; city; PF:8.6
    Ohm_Boy is offline Registered+ Thread Analyst Ohm_Boy 0
    Default Re: Shot glass method doesn't work with DPD?
    Dilution does work regardless of test. If you think about it, all of our chlorine samples are diluted - the test tells us how much. That's how it works.
    Naturally, further diluting the sample increases the scale and reduces the accuracy by the same factor.
