Re: 8 gallons of bleach...still green!!!
With algae, you're losing till you start winning. And you won't start winning, till you get enough chlorine in the pool to both start killing the pool AND maintain a residual.
People badly underestimate how much chlorine it takes to clean up a mess. Most of my experience is with large commercial pools -- and we kept records, in the early years when I still occasionally had algae outbreaks. Cleaning a single algae episode can take more chlorine than would otherwise be needed in a month!
On your pool, a gallon (not 3 quarts) of bleach will add about 6 parts per million chlorine. If your pool is still badly green, you probably need to think in terms of single doses of 20 ppm each -- about 4 gallons. Go get 12 or more gallons of bleach -- about the cost of a single bottle of algaecide -- and add a dose this AM, another tonight, and a third in the morning, unless it begins to clear. Once it begins to clear, make SURE the chlorine level NEVER drops before 5 ppm till the algae is completely gone.
Meanwhile, ignore all your other readings EXCEPT stabilizer. You need to get a test kit, or take it to a pool store, and find out what your stabilizer readings are.
You can't 'sneak up' on algae. You need to hit it hard and kill it quick. But, don't double up on the doses I gave you. If you get the chlorine high enough, you could end up bleaching out the liner.
Ben
"PoolDoc"
