Re: No poolguy this year to open pool, need help...
No need to replace the eyeball pieces. You probably didn't get all the teflon tape off the tight one. They're underwater anyhow so who cares if they leak around the threads a little. Don't use more tape. On the eyeballs there is a larger threaded piece that goes into the pipe. This has an outer thread for the eyeball retainer. I try and get the larger piece somewhat tight in the pipe just so it doesn't turn when I loosen or tighten the eyeball cover to allow moving the eyeballs. I made a tool from a piece of aluminum plate, maybe 1/8" to fit in the slots of the larger piece to screw it in and out of the pipe without buggering the threads.
