Thread: Scrubbing steps,ring around pool
    Digger is offline Subscriber Thread Analyst Digger 0
    May 2010
    Milton, PA
    Default Scrubbing steps,ring around pool
    I just changed from Baq this season and there was a cleaner that I used on the steps and around the pool liner to brighten it. I am assuming I cannot use the same cleaner on a chlorine pool? What does everyone use to clean with? There actually is not a dire need to do so, as there was with Baq, but would like to from time to time. thanks!
    Default Re: Scrubbing steps,ring around pool
    The easiest thing I know to use is a sponge with a paste made of baking soda and water. It doesn't create a chlorine demand if it gets into the water, and doesn't mess up any chemistry.
    Others have suggested Magic Eraser, but I'm nervous about any of the soapy stuff getting into my pool.
    Lehigh Valley, PA
    There's no soap in Magic Erasers. They're made of melamine foam and work by abrasive action, much like very fine sandpaper. They should not be used on painted, polished, or easily scratched surfaces. On a pool liner, they might rub the pattern off or fade it some.
    See How Stuff Works.
  1. Ring Pool
    By betolley in forum Intex-type Pool Setup & Operations
    Last Post: 07-09-2012, 12:35 AM
  2. Ground By Pool Bottom Ring Wet??
    By poolguy123 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-07-2012, 09:19 PM
  3. Brown oily ring around pool
    By Pamela P. in forum In-Ground Pool Construction and Repair
    Last Post: 05-02-2012, 01:22 PM
  4. Scrubbing a Pool
    By PoolMom in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-04-2011, 02:47 PM
  5. SW Pool and ring around the tile.
    By Tabby in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-02-2006, 11:25 AM
