Results 1 to 10 of 16
Thread: Pool Store vs Test Kit Results??
    Default Re: Pool Store vs Test Kit Results??
    It's great to see a newbie doing everything right! Usually, we all make super-duper mistakes at that time.
    Jan and Lisa have guided you correctly.
    Until you get the K-2006 you can dilute pool water with distilled water (the "CarlD Patented Shot Glass Method") to boost the range of your HTH chlorine tester.
    I like the shot glass because it's not too big, not too small and gives VERY precise dilution. So...1 shot of pool water and 1 shot of distilled water mixed together, then poured into the test block (or "cell") will allow you double the reading you get. If it reads "4", your chlorine is 8.
    If you use 2 shots of distilled to one of pool, you triple the reading--therefor if it reads "4" it's really 12.
    Hope this helps.
    Phoenix, Arizona
    Thanks Carl.
    Still no Taylor kit -- hoping for early next week. For now the shotglass method is working just fine. My only concern is that I am -- or at least it seems to me like I am -- using a lot of bleach. The FC is degrading at a rate of about 9-10 ppm per day, so I'm adding a full 182-oz bottle everyday.
    I suppose it is what it is, but is this typical/normal?
    Scott
    Can you post current water testing results? The last ones posted are from a couple of days ago. Losing 9-10 ppm of cl per day is a lot. Are you losing more than 1ppm from sundown to sunup? How does the water look?
    Phoenix, Arizona
    Hi everyone --
    Got my Taylor test kit today - here are the results from tonight...
    pH = 8.0 (has been 7.5-7.6 with HTH kit for days)
    Acid demand = 3 drops
    FC = 6.4 (was 15 this morning with HTH kit)
    CC = 1.0
    TA = 125
    CH = 700 (!??)
    CYA = 60
    Based on a CYA of 60, a FC of 6.4 would be right in the middle of the ideal range per the best guess CYA chart. Would that be high enough to throw the pH off, or is the 8.0 likely valid?
    Scott
    A cl reading of 6.4 should not affect pH readings. With a CC reading of 1.0, you are fighting something in the water and need to shock this pool and try and hold the cl at shock level until you can go from sundown to sunup without losing more than 1ppm of cl. Run your pump 24/7 for now. Wow! CH of 700? No using cal-hypo in this pool. Also, with a cya of 60, you don't want to use any trichlor pucks or dichlor powder. They will make the cya go up and you don't want it any higher. Stick with bleach.
    How ya like that new kit?
    Phoenix, Arizona
    Love the new kit! It will be much easier to get a handle on things now. Of course I don't need to tell you that. =)
    Morning numbers...
    pH = 8.0+
    FC = 6.0 (so lost 0.4 overnight)
    CC = 0.5
    I added acid this morning, but no bleach because I wanted to get a true picture of what was going on with the FC/CC.
    Evening numbers...
    ph = 7.5
    FC = 4.0 (so only lost 2 ppm during the day as opposed to the 9 that the HTH kit was reading - what a piece of junk!)
    CC = 0.5
    I'm definitely going to add bleach tonight, but do you still think I need to bring it up to shock level, or just bring it up to 10.0?
    Thanks!
    Scott
    I think if it were my pool and I had a CC reading of 1 less than 24 hours ago, I'd go ahead and shock it up one more time. Then, if you still have less than a 1ppm loss overnight, then let it drift down and I think you'll be good to go. (You are probably ok not to shock, but it is just kind of like insurance. Won't hurt.)
