Re: Robotic Vacs for IG Pool- Good and Bad Experiences Please
As I said in a different thread, also with TomC loving his. Mine is gathering spider webs. I manually vac. It is the difference between "picked up" and "clean" to me. The Aquabot does a decent job although it always misses some stuff, but it will get stuck on the ladder and sometimes on the main drain. I wouldn't run it if wasn't around paying at least a little attention to it. I guess, to me, there is something to starting the weekends in the summer with that sparkling, perfect, squeaky clean feeling liner (and walls). I tend a 33,000 gallon IG vinyl rectangle. I'm kind of in the woods too if that matters. I don't generally need to brush my pool after the opening fun, I just thoroughly vac 1X per week weather permitting. It takes about an hour and a half from start to finish.
Good luck, i hope you love it and it works out great for you!
PL
33,000ish gallon, 20X40 IG Vinyl Liner, no heater. Full sun, Sand filter. Been pool stored more times than I can count, not anymore! Thanks PF!
20'x40' rectangle 33K gal IG pool; Bleach; Hayward sand filter; AO Smith 1HP pump; 14hrs; Taylor K2006; utility water; summer: ; winter: ; iPhone; PF:3.6
