Results 1 to 10 of 14
Thread: constant ph battle
    Carlsbad, CA
    Default constant ph battle
    I've got a constant battle with rising ph, and always have. It bugs me, but maybe something I just have to live with. A little feedback here always goes a long way so I thought I'd give it a shot. My numbers:
    FC: 3.5
    PH: 7.8
    CYA: 35
    TA: 70 (might be slightly lower)
    CH: 250
    I use MA to lower ph, but have to do it consistently. I only use bleach as a sanitizer, which I've read is demanding on acid.
    I tested my source water, which is over 8.0 but I can't tell how far over with my test kit (k-2006).
    Is there anything I can do, or just keep doing what I'm doing?
    Thanks!
    Default Re: constant ph battle
    when you lower the pH how low do you put it? The lower the pH the faster it will rise from outgassing of CO2.
    What is the TA of your fill water?
    How are you testing the water?
    Carlsbad, CA
    Good question. I suppose I go from 7.8 to 7.2 or 7.4, something around there. I try to keep it in the recommended range. You think that's causing it to rise quickly?
    110
    k-2006, I mentioned that already, but maybe I'm missing your question?
    Thanks!
    Have you been adding baking soda to increase your T/A level?
    Normal T/A levels are from 80 to 120ppm and you are low at 70. Ordinary Arm&Hammer Baking Soda (or generic) is the same stuff they sell as "Total Alkalinity Raiser".
    You are adding MA to lower pH--that's normal. But you are bringing down your T/A with it and the aeration of your water (do you have a waterfall or fountain?) is, via the out-gassing Waterbear mentioned, probably what's driving your pH back up.
    So you add more MA...and it takes your T/A down some more.
    I'm not sure how to stop the out-gassing other than turning off fountains, waterfalls, pointing the returns DOWN so they don't roil the surface--and maybe using a solar cover when you aren't swimming. But Waterbear may have better suggestions for reducing it.
    Meantime I'd get the T/A back up. If you have a vinyl pool you may consider raising it higher. If you have a concrete/plaster pool, you may want to just take it to the upper range. Again, all you need to do this is baking soda.
    Again, Waterbear may offer a reason not to do this, but that's usually how we get pH to stop oscillating, unless, of course, you have another cause of the rising pH.
    waterbear gave you good advice last year in this post. Did you follow that advice keeping the TA low (say, at 70 ppm) and having a higher pH target not below 7.6 and seeing if the pH rise to 7.8 is slow enough to be tolerable? Did you ever add the 50 ppm Borates?
    I disagree with Carl on this one in terms of the recommended TA level. If the source of pH rise is due to carbon dioxide outgassing, then raising the TA level is only going to make things worse to accelerate the rate of pH rise and especially the amount of acid that needs to be added.
    Do you have sources of aeration such as waterfalls, spillovers, fountains or returns pointed upward? I agree with Carl that turning off such features (if possible) and pointing returns so that they do not cause waves or breaks in the water surface should help. Did you get your plaster resurfaced? If so, then the curing of such plaster will have the pH rise (and the CH as well) and there's nothing you can do about that but add acid, but this effect will slow down a lot after the first month and should become very slow after a year.
    In spas when using the Dichlor-then-bleach method, people sometimes need to get the TA down to 50 or even 40 ppm before their pH becomes stable due to the great amount of aeration in spas. They usually use 50 ppm Borates as an additional pH buffer and if you need to keep your TA low, even below 70 ppm, then you could do the same. Also, for your plaster pool, once you settle on a TA and pH level for pH stability you can then adjust your Calcium Hardness (CH) if needed to get to saturation index that is closer to zero (The Pool Calculator will calculate this for you).
    Richard
    Richard's right that you need to also look to a concrete/plaster pool (especially a new surface) for the source of your rising pH. If it's due to to the calcium in your pool walls, I can only suggest Richard is right you'll just have to wait it out.
    If, however, you have a vinyl pool, then we need to see if pH rising is due to out-gassing, rather than some other cause. If it's due to the aeration, then Richard and Evan probably have better advice for you than me.
    It's very odd to have a vinyl pool, with fill water with T/A of 110, and no aeration, have its pH rise so consistently. Normally we see that with concrete/plaster pools or with salt-water chlorine generators.
    Even with aeration SO much rising pH has me baffled.
    But please let us know if your pool has:
    1) Concrete/tile/plaster versus vinyl or fiberglass
    2) Salt-water chlorine generation
    3) Fountains, waterfalls, or other aerating devices.
    My vinyl pool has none of those things and it doesn't seem to matter if my T/A is 80, or 180ppm--my pH only seems to change if there's a clear cause (like leaving the pool for 2 weeks with lots of Tri-Chlor floaters). Usually, pH is pretty stable.
    Carlsbad, CA
    Got distracted with some other things, and I didn't see some of the advice until this morning. Thanks for all the help!
    To start, I'll make sure you know about my pool. It's a 25k gallon plaster pool with a spa. The spa spills over into the pool, so there is constant aeration that I can't really turn off. I also have a water feature that I run sometimes (my wife likes it), so that adds even more aeration. The pool is almost 10 years old, so it isn't a new surface issue. I stick to the BBB method, and do not have a SWG.
    Thanks for reminding me, it was actually two years ago. I did the Borates thing, that was a ton of Mule Team I added. To be honest, I wasn't crazy about the taste of the water after, but that's a separate issue. I haven't been religious about testing for borates since, so I'm not sure what the level is now. I honestly can't remember how much it helped stabilize my ph, but it did help. By now, without monitoring it, my ph is raging once again.
    I'm thinking it is a combination of the constant outgassing and my source water. But now I'm confused whether to raise the TA or not.
    Jim
    Just out of curiousity, how much dilution does your pool get with tap water? With a fill water pH of over 8, if you were constantly adding water from a slide, fountain, or a hose to replenish splashout, it could very well be contributing to the rising pH.
    It's just an idea....
  1. Phosphate battle
    By proximo in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-06-2012, 02:43 AM
  2. First Battle with Algae
    By tracker1412 in forum Dealing with Algae & Slime
    Last Post: 08-08-2012, 05:52 PM
  3. Constant Battle
    By LisaM in forum Dealing with Algae & Slime
    Last Post: 06-26-2012, 05:48 PM
  4. Progress finally, or The TA battle...
    By steveinaz in forum Dealing with Alkalinity and Calcium
    Last Post: 07-04-2010, 02:11 PM
  5. constant backwashing ?????
    By stma in forum Pool Equipment & Operations
    Last Post: 05-28-2008, 06:57 PM
