He'll need to keep adding acid and the waterfall will keep aerating and raising pH. Therefore the T/A will keep dropping.
But what effect will a low T/A have on the calcium in the plaster walls? That's STILL a separate question from the rising pH issue and has not been addressed.
If the plaster is at risk from low T/A, it's far less expensive to regularly add M/A and Baking Soda than to re-surface a pool prematurely. We cannot have a one-size-fits-all until you can show low T/A is not a problem for plaster surfaces.
