Results 1 to 8 of 8
Thread: Dirt returns to the pool after backwashing
    Default Re: Dirt returns to the pool after backwashing
    Thanks Watermom.
    It's an old sandfilter and I don't have a 'rinse' setting.
    Have you checked the spider gasket in the multiport backwash valve, or do you have a push/pull valve? If you have a push/pull valve (two positions, up and down) then the plunger might be worn and not seating well.
    Ontario.
    Are you backwashing long enough? The one time I had that happen to me was when I rushed and the backwash had not cleared out the junk yet. I wait until the small glass bottle at the top of the pump has clear water going through it. Not sure if that is possible with your set-up, just a situation with mine.
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    Do you have a "Waste" setting, so you can vacuum to waste? If so, the "Waste" setting is the same as the "Rinse" setting.
    Thanks guys,
    CarlD: I only have a push/pull valve so it's either backwash or standard.
    Spensar: Yes, I've backwashed several minutes past the point of when the water runs clear to be sure.
    Waterbear: It's a push/pull valve. I took the 'plunger' out today and examined it. It's old but didn't appear to have anything wrong with it. I lubed the o-rings up again and set it back in. After vaccuuming and backwashing tonight I held just a little hope that the reseating the valve would make a difference but no luck. It's like a punch in the stomach to see the dirt spew back out after vaccuuming in 110 degrees (AZ)
    Is there a telltale sign that I could look for if the valve isn't seated properly?
    Thanks!!
    bumping this thread back up....
