Do you have a "Waste" setting, so you can vacuum to waste? If so, the "Waste" setting is the same as the "Rinse" setting.
Thanks guys,
CarlD: I only have a push/pull valve so it's either backwash or standard.
Spensar: Yes, I've backwashed several minutes past the point of when the water runs clear to be sure.
Waterbear: It's a push/pull valve. I took the 'plunger' out today and examined it. It's old but didn't appear to have anything wrong with it. I lubed the o-rings up again and set it back in. After vaccuuming and backwashing tonight I held just a little hope that the reseating the valve would make a difference but no luck. It's like a punch in the stomach to see the dirt spew back out after vaccuuming in 110 degrees (AZ)![]()
Is there a telltale sign that I could look for if the valve isn't seated properly?
Thanks!!
bumping this thread back up....
