Thread: I have my K2006, now have questions...
    Jun 2010
    South MS
    Default Re: I have my K2006, now have questions...
    This is Tricia's DH Matt. After adding 1,130 grams of 6% bleach last night at 11pm. Tested pool water at 8:40am.
    pH 7.9
    FC 4.5ppm
    CC .5ppm
    CYA 42 Tested using method suggested in earlier post. Waist high back to sun.
    What should we do next?
    Tricia from South MS
    Intex Above Ground Metal-Framed Pool 15' x 48" (~5000 gallons) installed 6/21/10, and now using BBB (well only one of the B's so far) and Taylor K-2006 test kit
    Go swimming!!! Keep the chlorine at the 3-6 ppm level, might want to add a little muriatic acid to get the pH down to the 7.2-7.6 range, and enjoy the pool. Continue testing daily for the next several days, and you'll start to get a "feel" for how much chlorine you're losing during the day. That will help you decide how high you need to raise it before leaving for vacation.
