Hey Tabitha;
You'd gotten two earlier responses, from CarlD and Waterbear, that were sort of going at cross-purposes, so I'm jumping in here. I moved those posts to the China Shop for now. They are in the "Algae, TA or what" thread.
As I understand it -- please correct me if I'm misunderstanding -- you have two problems, one urgent and one longer term or chronic.
The urgent problem is the algae. If it gets away from you, you'll have serious problems, so we probably need to get that under control ASAP. More chlorine is the solution, at least right now.
The chronic or longer term problem is a continuing rise in pH. This problem may contribute to your algae problem, since chlorine tends to be less and less effective as the pH rises. So, lowering your pH -- regardless of how why it keeps going up -- is probably the next thing to do, after you get your chlorine level up.
So, let's do this.
1. Raise your chlorine level to 15 ppm, and then keep it above 10 ppm till the algae is gone.
2. Add enough acid to lower your pH to 7.2 or so -- but NOT all at once. If you know how to handle muriatic acid (no splashes, wear glasses, use gloves, don't breath the fumes) it's cheapest and best for your pool.
3. Don't try to fix anything else, till the algae is gone.
4. BUT, do collect the info we need to see if we can tell what's going on with your pH.
Regarding doses, I don't see any indication of pool size, but if you post gallons, we can figure doses or show you how.
If you're not doing so, make sure your pump is running 24/7, till the algae is gone.
As far is information goes, please do all the following (but take care of the chlorine and pH first):
1. Post pool gallons, typical timer 'ON' hours, filter type.
2. Tell us what sort of chemicals you are normally using (labels, chemical ingredient)
3. Tell us what's been happening with your TA -- has it always been this low, or has it been going down lately?
4. Test your FILL water for pH, chlorine, Alk, Calc, and post those results.
5. Tell us if there is anything connected to your pool that would aerate the water (fountain, waterfall, spillover edge, attached spa, air jet, etc.)
And, let us know you have a problem with any of this.
Good luck!
Ben
"PoolDoc"
