Results 1 to 10 of 16
Thread: How much bleach?
    Jun 2010
    British Columbia, Canada
    Smile How much bleach?
    Hi,
    Pool has been set up for about 8 days. Intex 12'x30" vinyl. 1700 or so gallons.
    Numbers have been fairly consistent for about 4 days. Just tested this afternoon with taylor K 2006.
    Here are my numbers:
    PH 7.6
    FC = 4ppm
    CC= 0
    TA= 120
    CYA- tested first thing this a.m. and was 40ppm. First time testing this. Was a bit tricky to see exactly when the black dot disappeared. Very hard to see dot at 40ppm.
    Upon setting up the pool I was advised to use 1 lb of dichlor over a bit of time and at that point my CYA should be somewhere around 40ppm. I am just a few TBSP away from using all of the dichlor. ( about 7 TBSP left). I appear to be losing on average of about 2, 2.5 ppm of chlorine during the course of the day. Since my FC was 4ppm at 1 o'clock I added 1.5 TBSP of dichlor to tie me over to the evening. I have been maintaining FC anywhere from 3-6 ppm. CC has be 0 for a few days.
    My question now is, since my CYA is 40ppm when should I switch over to the bleach and how much. We are going away for a couple of days tomorrow and I have no one to manage the pool Any suggestions. I am a bit nervous. Not sure if I will let the pump run 24/7???? and not sure what I will come back to. Our temps right now are anywhere from 90-97 degrees.
    Thanks to everyone who helped me get to this point. My family is enjoying the pool and thanks to all of the advise, so far pool has been crystal clear. Continuing to add borax and soda when needed.
    Default Re: How much bleach?
    Your numbers are FINE!
    Little Intex donuts can be a lot of fun--We had a 15' for 3 years.
    Now you can start using bleach to chlorinate your pool, which is really, really cheap and effective.
    One quart of regular 6% bleach will add almost 9ppm of chlorine to your pool. I suggest before you leave you add that quart to raise it near-shock level, cover it (the Intexes usually come with a cover) and don't worry!
    One pint of bleach will add 4.4ppm of chlorine to your pool. The Di-Chlor has done its job. You have a nice CYA level, your pH is good, and the bleach won't affect either. Plus you can get it anywhere!
    Jun 2010
    Will it matter if my filter is running or not?
    I would make sure and run it for at least 2 hours after your bleach addition, and then you can shut it off it you want to, especially if you're covering it. If it's only for a couple of days, then you shouldn't have any problem at all--and even if you do, the fix is pretty easy!
    I had an inexpensive plug-in outdoor timer I used on my Intex. I think it was about $40 or $50 and it hung on the wall next to the outdoor outlet, designed for outdoors. I'd run the pool 8-10 hours/day.
    My friends down the street have the same type of timer on theirs, but their pool is under a big oak tree with lots of big leaves that clog the skimmer. Running the pool while you're home is obviously a necessity, but while you're gone, you'll have to make the decision as to whether you can safely run it without plugging up the skimmer with leaves, etc. or not. As I mentioned in my post above, if it's too risky, then it would be okay for a couple of days without running. If it's not a danger, then by all means run it via timer!
