Results 1 to 10 of 16
Thread: How much bleach?
    Jun 2010
    British Columbia, Canada
    Default Re: How much bleach?
    Will it matter if my filter is running or not?
    I would make sure and run it for at least 2 hours after your bleach addition, and then you can shut it off it you want to, especially if you're covering it. If it's only for a couple of days, then you shouldn't have any problem at all--and even if you do, the fix is pretty easy!
    I had an inexpensive plug-in outdoor timer I used on my Intex. I think it was about $40 or $50 and it hung on the wall next to the outdoor outlet, designed for outdoors. I'd run the pool 8-10 hours/day.
    My friends down the street have the same type of timer on theirs, but their pool is under a big oak tree with lots of big leaves that clog the skimmer. Running the pool while you're home is obviously a necessity, but while you're gone, you'll have to make the decision as to whether you can safely run it without plugging up the skimmer with leaves, etc. or not. As I mentioned in my post above, if it's too risky, then it would be okay for a couple of days without running. If it's not a danger, then by all means run it via timer!
    Jun 2010
    Talking Re: How much bleach?
    Hi,
    I am back!! This afternoon we returned home to a very clear pool! YEAH!!!!!
    Here are my numbers:
    PH 7.4 -7.5 Very close
    FC 8.5
    CC 0.5
    TA 130
    I did as was recommended and added 1 gallon of bleach and let the filter run for 3 hours prior to leaving and then covered.
    Do I need to do anything at this point to bring down my FC and CC? Not sure how to do that...
    Thank you again for the advise. I am so glad I found this great group of people. I honestly did not think of the pool one time while away. I just had enough faith in what I have been told thus far and I will continue to swear by the BBB method!
    By the way... I love my test kit. I feel like it is so accurate and takes away all of the GUESS work
    Carrie
    Last edited by drako4; 07-12-2010 at 11:54 AM. Reason: amended amount of bleach to one quart. Not a gallon.
    The FC will come down on its own. If someone has a CC level above 0.5, we recommend shocking the pool. If it is 0.5 or below, you are ok ------ although, if you want to shock the pool to get the CC down to 0 that is fine, too. Glad it was clear when you got home!
    Jun 2010
    Smile Re: How much bleach?
    If I decide to shock the pool, approx. how much bleach should I put in? As the FC comes down on its own, will the CC as well?
    Do I need to test my CYA again at some point?
    Cheers
