Results 1 to 10 of 13
Thread: Check/Clean Cell Purifier off
    Ft Lauderdale, Fl
    Default Re: Check/Clean Cell Purifier off
    rebomax,
    The low amps and volts can indicate either a bad control power board, or an incoming power issue to the Pool Pilot. That is, if it's wired to accept 220 volts but only getting 110 volts, it will send approximately half the amps and volts that the normal power should be.
    If it were just a bad cell fuse, bad cell cord, or bad cell, you would peak out at 29 volts and lower amperage (less than half the cell power amperage).
    Even with the check system light flashing, the Check/Clean Cell message is still producing some chlorine, just less than half as much.
    Sean Assam
    Miami, FL
    Question Re: Check/Clean Cell Purifier off
    Thanks for replying. I just got back in to town. The system is setup for 220 VAC and getting that at the connections. When I do the self test I get 15 v and 3.6 amps, at the cord end I'm getting 28.5 v. When I put it on boost it says check/clean cell. When I put it on power level 3 @ 50% it says cell amps. All 3 fuzes are good. I replaced the cell and the readings are the same. How can I check to see if it's PCB?
    Ft Lauderdale, Fl
    There are no test points on the board to determine the condition of the board that I would be able to provide. However, I know you said it was set up for 220 volts (and excuse this question, but I have to ask), did you test this with a multimeter?
    You can visually inspect the power board for signs of burns and swollen capacitors (tall cylinder components along the top left corner of the board), and check under the pcb for insects or reptiles (ants, lizards, snakes, etc).
    Sean Assam
    Miami, FL
    Yes Sir, I did check with a multimeter plus the pump is also working. I will check the card for burn marks and bugs. Do you know if that part is available somewhere? I also have a Jandy RS-6 with a PDA. My son dropped the PDA and oops the LCD screen is cracked. Does any one where I can one for a good price?
    Miami, FL
    Check Power PCB no visible burn marks no bugs clean both PCBs with electronic cleaner and is still doing the same. Any other suggestions, I need help badly.
    Ft Lauderdale, Fl
    It sounds like its a bad power module, unfortunately.
    Sean Assam
    This might not make sense but I believe in trying everything before ordering new stuff
    I had a check/clean cell warning one time and like you even though it didn't look really dirty I cleaned the cell as directed but the message came back shortly after putting everthing back together. After playing a bit (cleaning contacts, etc) I finally thought about checking the inline filter screen and even though I didn't have a flow warning it was pretty dirty so I cleaned it out and Viola!! the message went away.
    I didn't get as far as checking voltage/current readings and have no idea why the system was reporting cell warning rather than flow warning (which it does when the filter screen gets really dirty and the pump is on low). Maybe it triggered both alarms and the cell warning has a higher priority so it was the one being displayed and would not clear until the flow was sufficient to check the cell. Perhaps Poolsean can explain or tell me I'm crazy or it could be one of those pool mysteries that is never solved but it worked for me so maybe it will work for you!! Good luck.
