Results 1 to 10 of 14
Thread: Dropping TA, for the workin man or woman....
    Jun 2010
    Phoenix, Arizona
    Default Re: Dropping TA, for the workin man or woman....
    I sure hope you don't get point 5 all turned around
    Dan
    10,000 in ground, concrete w/PebbleTec surface, waterfall
    420 sq. ft. cartridge Pentair filter, In-floor popup cleaning system, 2-1 hp pumps (1 for popup system)
    sturev's Avatar
    sturev is offline Registered+ Thread Analyst sturev 0
    May 2010
    ya Steve, make sure to keep the acid away from the beer on step 5!!! I hope your beer and acid containers don't look anything alike
    Evan S.
    AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
    Yeah, all that good beer in the pool trying to bring down the pH!
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Quote Originally Posted by dhanger View Post
    Dan
    Wait a minute...that might explain my TA plateau on day 5?
    Jun 2010
    Phoenix, Arizona
    This "rising pH" seems to be a theme lately, there's a couple other threads discussing it. The one with chemgeek and pooldoc discussing higher level chemistry is interesting to me but over my head right now, but it sounded like chemgeek was suggesting that pH looks for it's own plateau based on some other factors, including a TA lower than 80.
    This is the first year (in 5) that I've paid close attention to my water balance, and have the same issue of rising pH. Lately I've been adding acid nearly every other day to counter it, but I'm tempted to leave it alone for a few days to see if it does level off. I haven't recorded a level above 7.8 yet, but that's because I haven't allowed it any higher. Steve, sounds like you're saying that the high TA was the problem, and you've stabilized it now with lowering the TA. My TA has been floating around 80-90 since I started checking about 3-4 weeks ago, but the pH still rises relentlessly. I'm really scratching my head at this point.
    On a related note, since my pH does rise, and I haven't kept a close eye on it for a long time and it probably got way out of control at times, the pool calculator says that (given higher CH levels in Arizona) the SI rises with it, which probably explains why my pool developed such a thick calcium ring within the first two years. It got so out of control without me realizing it, that by the time I tried to do something with it, it was beyond my puny efforts. I've just let it be for the last couple years, but a few days ago, while in the pool, I noticed that the ring on the tile portion was starting to disintegrate on its own. I tried some pumice on it, and with a little elbow grease the rest of it came off, which didn't work at all in the past. My only thoughts are that keeping the pH in balance better is having an effect on the existing ring. Well, that and having drained and refilled completely last May, which lowered the CH considerably (in fact I had to add calcium to raise it to it's current level of 190). Don't know if I'm interpreting all this correctly.
    Dan
    Dan,
    Do you have a SWCG system? They are known for raising pH. Plus you have a concrete pool--have you been keeping your calcium levels correct?
    With a concrete pool we still are not convinced that lower TA levels as a good idea. The chem guys have to figure in the calcium, calcium carbonate, leeching, etc.
    Jun 2010
    Phoenix, Arizona
    No, I don't have a SWCG, just using bleach or LC now. Up until I hit this forum (about 4 weeks ago) and converted, I was using a Pool Frog inline chlorinator, which used tri-chlor cartridges (and would raise the acid level as I understand), but I don't use that anymore.
    Regarding calcium, here's what I wrote in the previous post-
    Prior to that, I don't know what the CH level was, as I never tracked it
    So, would you say that I should keep my TA level at it's current 80 or higher? That would make sense to me for concrete, as you say.
    Dan
    Southern Arizona
    Dan
    I don't know about your fill water, but here in Sierra Vista the fill water TA is 170ppm--I'm sure this contributes to the rising pH problem around here. All of our friends with pools also battle rising pH on a constant basis.
    Jun 2010
    Phoenix, Arizona
    I just checked, the fill water TA is 90, and the CH is 80.
    When I first started testing my water, about 4 weeks ago, the TA was low, don't remember how low, but it was lower than the recommended 80-120 for concrete/plaster, so I added enough baking soda to bring it up to 100. The next test was at 90, and yesterday it was at 80. So if alkalinity is dropping, acidity should be rising, which means pH should be going down rather than up, right? And yet it goes up. There must be something wrong in my reasoning here, hopefully the experts can straighten me out.
    Clearly, though, I have an issue with the TA dropping, which must mean I have some unwanted aeration going on. I never use the waterfall, the returns are down or sideways and never break the surface, about two weeks ago I disconnected the ozonator which I determined was a suction side device and PoolDoc suggested could be aerating, the only thing left that I can think of is my in-floor popups, which when I use them, definitely ripples the surface a lot in the shallow end. Until a couple weeks ago I was running that every night, but I've stopped that practice just to see what effect it would have on the cleanliness of the pool, and to conserve electricity. So I think I'll add some more baking soda and keep testing to see if that makes a difference, and just use the popups when the floor is actually dirty!
  1. something is dropping clay in my pool!!
    By alisonquilts in forum Pools, Pets and Creepy Critters
    Last Post: 06-30-2012, 09:37 PM
  2. PH Keeps Dropping
    By rilesworld in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-08-2007, 03:32 PM
  3. water level dropping
    By carolynn in forum In-Ground Pool Construction and Repair
    Last Post: 08-03-2006, 04:49 PM
  4. Dropping ALK questions
    By medvampire in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2006, 03:43 AM
  5. Quick Question About pH DROPPING???
    By PopcornGirl in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-22-2006, 12:18 AM
